Definitely need fewer teeth for cutting that sort of depth. Those high tooth count saws are for shallow slots. Same sort of principle as a hacksaw blade, you wouldn't cut that deep/wide with a high tooth count blade. You need a 36 tooth or similar. Though they'll all wander if you do really deep.They are pretty grotty aren't they? Wasn't sure if it was just me, it usually is. Worth a try though to experiment with. Maybe one with fewer teeth would be better? I'm not spending any more money to find out.
Luckily a 40 taper Bridgeport (clone) has an enormous work envelope.
It's often the same with a lathe. Takes ages taking sensible cuts and a CNC makes it look like child's play.I had a local fabricator make a nose cone for a space ship with a 75mm hole in the top, then realised I actually need it 5".Luckily a 40 taper Bridgeport (clone) has an enormous work envelope.
I tried to trepan it out but it made a terrible noise, and interpolating with a small endmill was no better, so I resorted to taking over two hundred, approx 0.2mm passes with a boring head. Never again.![]()
Only Allah is perfect ....its a 3 jaw self centering chuck none of them are totaly accurate
Didn't he make hexagonal wrenchesOnly Allah is perfect ....
Only the geometry bit.Didn't he make hexagonal wrenches![]()
What is it in the last photo?First slots on the mill, on any mill I'm going to get a dro, what's everyone's preference,and a bit of skimming
View attachment 453643 View attachment 453644 View attachment 453645
Its slightly lighter than the colour on my Tom Senior mill, almost matches the shade on the Fobco drill press. Paint was from Aldi, and I've used it on several tools, like the vice in the photo.Ton Senior colour?
