Yeah, was missing a fair bit of antifreeze, engine oil suggests it needs changing asap, no visual emissions at all from exhaust, engine runs sweet as a nut.Without wanting to put a downer on you,
Rather shows the state of "maintenance" of the car.
Time for a through servicing methinks...
BTW Is that penicillin growing on the back seat ?Yeah, was missing a fair bit of antifreeze, engine oil suggests it needs changing asap, no visual emissions at all from exhaust, engine runs sweet as a nut.
Sunday...BTW Is that penicillin growing on the back seat ?
Damm good clean needed too!
https://www.ebay.co.uk/itm/3735370802433 litres of ATF: TBC, and I'll rinse and replace with the correct,
We buy bulk from Motul, will check grade tomorrow.
The boot is pretty mouldy.Just remembered, check the cubby box in the boot floor, they tend to fill up with water, I drilled a drain hole in mine.
Fingers crossed, I was bloody shocked when it moved, more so it went through all the gears correctly.If the box has survived the abuse it sounds like you've got one of those rare bargains!
It's a rare thing, maybe I'll buy a lotto ticket tomorrow, that won't work.I could do with some of that luck right now
I'm not even going to answer that, you .....So it manual or automatic?
Ah, facelift model, nice...Photos, I'll caption them in a couple of minutes.
Complete replacement new brakes, no disks, and some rubber pipe.
The one litre of brown filth which came out.
View attachment 451488View attachment 451489View attachment 451490View attachment 451491Rear window fully functional, all windows good, all lights good, headlights need polishing. A.C. needs recharging, as that's not working, on start, all warning lights come on, and go off, pro body work shop bloke next door will respray bonnet for mates rates....
