Onoff
- Sevenoaks, UK
The cleaners probably pulled the plug out when they were vacuuming.![]()
Cleaners? Only got the one...
At the server, not you!Cleaners? Only got the one...
Thanks ON off .Here you go. Check if the spares list is for the EU model though:
Thanks ON off .
Apologies for the delay in acknowledging your PDF info , Alison & I have only just returned for a lovely time at a friends four double bed villa in the Algarve well away from the tourist crows. . Loads of golf courses locally but neither of us play golf so we went sight seeing most days instead ,
Portugal in the Algarve .. is truly amazing in the spring .
Talk with Fizzy I'm sure he will be able to help you outThat's it, rub it in![]()
That's fantastic what brand is it?Big job on this evening, to repair the 12mm socket loose pouch
Some hot melt glue and sorted
You wouldn't get any limescale, though.I wouldn't care I used distilled water to keep the chance of bacteria to a minimum.
Ah yes I remember doing the ball joints on ours, if you find a decent half shaft oil seal that doesnt leak let me know!View attachment 441688
I knew owning a Land Rover would involve a lot of work, but every time i touch it i find more things that need fixing.
I replaced the oil seals on ours as everyone was saying "you should change them!" and they have leaked ever since
If you fish out the seal spring and overlap it by a couple of turns, often that's all it needs to make a better seal by putting a little bit more pressure on the lip.Ah yes I remember doing the ball joints on ours, if you find a decent half shaft oil seal that doesnt leak let me know!
It's a few years since I had a D2, there was a long running thread on the D2BC forum where people were having issues with new seals leaking. Apparently most aftermarket seals are the wrong size and leak, someone on there had found a source for the correct Cortico seals and there was a link.Ah yes I remember doing the ball joints on ours, if you find a decent half shaft oil seal that doesnt leak let me know!
Pigeon poop on it alreadyI was given a couple of bird-feeder stands last year. I came to assemble today...
Typical.
I had an old piece of gas barrel, so cut a sleeve from it and dressed the joint.
View attachment 441877View attachment 441878
Rammed it together and put some metal glue on.
Not the prettiest of jobs, but it's not going into a competition, after all![]()
