Farside
Badly Welded Man
- Ireland
Fork 'andles? There's only three.You didn’t see the state of the andles
I forgot to post this one here, this was written mid February.
car is back in the workshop today for the first time this year.
and I've finally fixed the dash! its only been a year!
after a long consult with aim they told me that you don't set the dash to link g4 in can settings, because reasons. you need to set it as per in the pics.
link side...
and aim side...
it works. woohoo!
I'm also 9/10th of the way to setting up the fuel level sensor too... i have a reading, just gotta set the mv settings, so I need to drain the tank and start filling it up 5l at a time until full. it currently reads -25l :lol:
The cleaners probably pulled the plug out when they were vacuuming.The Starlink that was down here. Lad emailed them. They did something, it came back on.
At the server, not you!Cleaners? Only got the one...
Thanks ON off .Here you go. Check if the spares list is for the EU model though:
Thanks ON off .
Apologies for the delay in acknowledging your PDF info , Alison & I have only just returned for a lovely time at a friends four double bed villa in the Algarve well away from the tourist crows. . Loads of golf courses locally but neither of us play golf so we went sight seeing most days instead ,
Portugal in the Algarve .. is truly amazing in the spring .
Talk with Fizzy I'm sure he will be able to help you outThat's it, rub it in
That's fantastic what brand is it?Big job on this evening, to repair the 12mm socket loose pouch
Some hot melt glue and sorted
You wouldn't get any limescale, though.I wouldn't care I used distilled water to keep the chance of bacteria to a minimum.
