If anyone wants more info I made a shaky video on the repair. It has an overview of the PCB main components at the end for future reference.The Sino SDS6-3V DRO on my lathe has had an intermittent fault where it would lose a column of digits. Yesterday it turned into a continuous fault so it was time to have a look at it.
I managed to find a data sheet for the dual 7 Segment display modules. They used pin 13 and 14 for the common pin on each side.
Got the scope out and found the signal on the dead column (pin 14) to be a distorted version of the signal on all the ithe columns.
Looking at the board I wasn't sure where to go.
Eventually I figured out the three big chips on the left (Darlington transistor drivers) were handling the segments for x,y,z and there where a bunch more on the right which were for the alphanumeric display on the right. So what was handling the columns?
I eventually noticed this row of transistors and probed the tabs (output) and found the column signal. Transistor 4 had the same dodgy signal I had found before
Signal on the base matched the others.
So after a bit of hard probing
The column started working again - it was a dodgy dry joint!
I've reflowed all of the transistors and now it's working fine.
Really pleased as it's saved me at least 150 quids, and very much at the limit of what I could achieve with no schematic.
They are just worn inI think you spent money on the wrong ends
You didn’t see the state of the andlesI think you spent money on the wrong ends
Fork 'andles? There's only three.You didn’t see the state of the andles
I forgot to post this one here, this was written mid February.
car is back in the workshop today for the first time this year.
and I've finally fixed the dash! its only been a year!
after a long consult with aim they told me that you don't set the dash to link g4 in can settings, because reasons. you need to set it as per in the pics.
link side...
and aim side...
it works. woohoo!
I'm also 9/10th of the way to setting up the fuel level sensor too... i have a reading, just gotta set the mv settings, so I need to drain the tank and start filling it up 5l at a time until full. it currently reads -25l :lol:
The cleaners probably pulled the plug out when they were vacuuming.The Starlink that was down here. Lad emailed them. They did something, it came back on.
