roofman
Purveyor of fine English buckets and mops
- North West with water on 3 sides
More info needed, I also have one where the handle is stuck, did you just take the cover off and clean or completely dismantle itAsked a mate if he had a vice for sale. Left me a message. Vice collection has now grown by five, plus two others bought at the weekend. Oops.
The mag vice was in poor condition. Handle seized. Stripped down, cleaned out, and surface ground the inside sliding face. Reassembled. Smooth action. No loss of magnetism. Next job grind top and base.
Flipped over and removed all screws. One already missing - someone had been fiddling. Punched through all pins. Switched magnets off. Now right way up. Used two flat pry bars with spacer between to separate (just) both parts. This needed a great deal of care not to lose fingers! Put packing in to reduce risk of finger loss. Then separated, quite easily. Inspected. Cleaned out junk. Checked linkage/cam. Underneath of top face corroded, so surface ground flat. Lubed. Reassembled with no loss of digits (just). Nudge into alignment. All pins and screws back in. Surface ground. Job done.More info needed, I also have one where the handle is stuck, did you just take the cover off and clean or completely dismantle it
Apparently this model as stood the test of time then, as Abus are still making it. I see them going for as much as £148.oo (new) on the bay of evil, but I won this used one by posting a hail mary bid of £22.oo and got lucky. It was a bit rusty, but a spray of WD40 along with a Scotch-Brite pad and use of a .45 cal. pistol cleaning brush down the shackle tubes got it functioning smoothly.I had one of those Abus Granit disk locks thirty (?) years ago, mine did not have the painted shackle though.
Neither did it have the day glow cord and yes I did try to ride off with it on the disk, but only once.
I actually suffered very little damage, keeping the bike upright as the wheel had only about a quarter of a rotation before the lock hit a caliper.
yes, that's the one.
A probably broken or just batteries...
An air fed Esab warrior tech parp
The mask itself isn't my priority it would be just worth enough to save the parp system
Yeah, so much is discarded nowadays because of the disposable mentality of modern times.
Edit: One thing I've noticed, are the huge number of vacuum cleaners dumped at our recycling centre, most likely thrown out because people haven't cleaned the filters.
No they don’t, thats why they are at the tip.That sucks.
That sucks.
I got rid of one of mine, all it did was gather dust.No they don’t, thats why they are at the tip.![]()
Extraordinary likeness there @The_Yellow_Ardvark !There is one more item of the box of sadness.
