Sergei Slovenija
- Slovenija Ljubljana
Bostik cementone.What brand/flavour?
Don't forget fire stopper and fire rated sealant.Guards, for a hole in a wall and pipes of the oil heat carrier. Pressed mineral wool will be inserted into the wall opening. Expansion and elongation compensation provided
I bet that took some cleaning up of the mill tableToday, using a set-up that was stretching the envelope of my milling machine a bit (both rotary table and tailstock were sticking out beyond the end of the t-slots so I had to use some alternative clamping methods):
I made a 400 mm profile that resembles a (bad) artist's impression of a gear
I then turned (pun intended) the end of it into a knob:
I need to make 5 more for the tool chest, but there's enough profiled stock there to make another 17, so I've got a bit of room for error
I could have just knurled it as I usually do, but I thought I'd try something a bit different. If I find I like using the knobs, it'll be very easy to make more for other projects now that I've done the mill work.
What diameter is it?
I bet that took some cleaning up of the mill table![]()
I can relate to that, only a l200 engine but turning it around was a touch and go feeling ,heart in mouth feet well out the way, thinking on updating it with a decent bearing and something to turn it steadily , small ring gear or similar,on the todo list.Because I didn't trust the chinesium engine stand I had. I didn't trust it with a 270kg aluminium V8 let alone a half tonne Perkins lump...
Foam concrete wall. Oil temperature +80. It's hard to ignite.Don't forget fire stopper and fire rated sealant.
True, but EU rules says you need fire stopping.Foam concrete wall. Oil temperature +80. It's hard to ignite.
Shields on both sides of the wall, drawn to each other with studs and 250 mm of mineral fiber between them.True, but EU rules says you need fire stopping.
Ctrl-C, Ctrl-V, Ctrl-V, Ctrl-V, Ctrl-V, Ctrl-V, Ctrl-V, Ctrl-V, Ctrl-V, Ctrl-V
tat looks tasty. save us a bit!
