blackolive (Ste)
- Chorley
Have your falsies fell in itTonight I'm making a dent in the homemade sloe vodka. All the better for being drunk out of the homemade glass!
Did a lhd and rhd heater valve for the MGZT260 owners club shop. Im extremely impressed with the mapp gas torch I bought the other week
View attachment 389500 View attachment 389501 View attachment 389502 View attachment 389503 View attachment 389504
Thanks Ill get a propaneI wouldn't use mapp gas to do soft soldering, its too hot & its very easy to overheat the fittings & boil the solder & flux. You are better to use straight propane (black or red cylinders), they don't burn as hot & are much safer.
Its not that much hotter, just use a smaller flame. However propane is cheaper, and butane/propane mixes far cheaper if thats all the heat you need.I wouldn't use mapp gas to do soft soldering, its too hot & its very easy to overheat the fittings & boil the solder & flux. You are better to use straight propane (black or red cylinders), they don't burn as hot & are much safer.
As you get older & your hands aren't as clever as they used to be and you don't like bending your back to use the chuck keys etc . Now is the time to make two chuck keys , 400 mm long with half inch sleeves of aluminum epoxied on the handles to make them 16 mm in dia & 250 mm from tip to tip .Needed a chuck key. After setting the dividing head, thought I might as well make spares.
Brake pipes, they must fit them on the car first and them put all the other gear in! not getting caught out this time so while its in the air im doing the lot! they havent done bad for 20 years
View attachment 389938View attachment 389939
He has a mechical bent.
Corrected.
Phone typing.
It's too early really for crap puns but nevermind.
