Onoff
- Sevenoaks, UK
As you get older & your hands aren't as clever
I find slightly loose trousers and an elasticated belt a boon if you're "in a hurry". No fumbling etc.
Brake pipes, they must fit them on the car first and them put all the other gear in! not getting caught out this time so while its in the air im doing the lot! they havent done bad for 20 years
View attachment 389938View attachment 389939
He has a mechical bent.
Corrected.
Phone typing.
It's too early really for crap puns but nevermind.
Now I have an image of a sort of JCB-Human hybrid type thingthe digger man
Nice, I think you want to be turning your rotary table (mole grips), more slowly.The accompanying video:
I was thinking it needs constant lubrication whilst cutting. That and do a cut and withdraw the tool rather than winding the spinning tool back though what you've just cut.
Would it work to do the first cut then stop the lathe and wind the helical jig back to the start. Then fire up the lathe and do the second cut?
The principle is there.
Good call by your digger manI'm not getting the welder(s) out in this rain. The extent of my making today has been 4 rivnuts in my mate's camera bracket!
Too wet for the digger man to cross the lawn and do my earth pit too![]()
Three years ago I purchased an old 1950/ 60's mahogany single plank 1 & 1/4 " thick French polished coffee table top for £ 34 inc carriage off eBay, 3 x 4 foot oval covered in paint & crud but underneath after scraping it off with plate glass scrapers it was OK for what I wanted Sometimes it's a good place to pick up worthwhile wood .More wood bothering - designed in fusion but I just exported the dxf. You can use the CAM part of fusion to generate gcode directly but it’s a whole new thing to learn. But for more 3D carving it’s probably a necessity.
‘For now I’m still using a recycled pine shelving unit for donor material. Getting hold of nic bits of anything more exotic, even oak, has so far eluded me.
Spring is meant to keep the jaws apart so you can open one handed whilst holding something hot in the other hand.The spring issue is sorted, someone was saying it was back to front?
