Scalarocco
Smile, or I'll bite your leg...
- Rossendale
We use a company called D Turner & Son for machine moves. They are Manchester based, so probably a non-starter.
How much do you think it should cost ?£10k moving is a bit savage though!
If he can do the stripping down work himself and the hauliers just have to crane it on and deliver I would have thought under £5000 depending on distance etc.How much do you think it should cost ?
That's where the money is, the clock ticking while the riggers dis-assemble, and then re-assemble.If he can do the stripping down work himself and the hauliers just have to crane it on and deliver I would have thought under £5000 depending on distance etc.
That would be to provide a low loader and another lorry with a very big HIAB for lifting. Depends on weight though. The biggest HIABs go to about 90 ton/metre.
I've fitted a couple of 150 ton per meter cranes to 8 wheel tractor units .If he can do the stripping down work himself and the hauliers just have to crane it on and deliver I would have thought under £5000 depending on distance etc.
What is the hourly rate on those ?I've fitted a couple of 150 ton per meter cranes to 8 wheel tractor units .
I've no idea as I only fitted them , I could ask the owner though.What is the hourly rate on those ?
Wow even bigger than I thought.I've fitted a couple of 150 ton per meter cranes to 8 wheel tractor units .
under £5k if he can do the dismantling and prep for lifting himself.How much do you think it should cost ?
If you were closer i would of given you a weekend myself fella...That machine needs got at all cost@bR39Da is going to help me strip it down overwise I’ve lost my money. As Brian at Bluediamond told me this morning. “It’s time to start getting yer hands dirty again ’
I suppose I’ve got used to being a Devlieg pilot![]()
Sweet Jesus, where do you start taking that apart?Went to look at the grinder this morning and pick up the two items I acquired.
These two gentleman kindly stood in to model the real world size of the machine.
Looks like there is an overhead crane to help.Went to look at the grinder this morning and pick up the two items I acquired.
Cross rail needs to come off as it’s 16’ long making road transport a no noLooks like there is an overhead crane to help.
Does the cross rail need to come off separate, or just the whole upper structure in one go ?
