It was, yes.Isn't that a petrol blow lamp?
Going back to the bathroom sink problem View attachment 372544
Going back to my post about the waste pipe from the bathroom sink I was about to try &sort it once again today , discovered that the " plumber had cut two waste pipe holes in the wrong positions.
Middle hole is filled with expanding foam , top hole is where the out of position leaking waste pipe now is.
Not sure if the outer wall waste pipe hole is viable at present.
I'm looking to see if I can core drill a new waste pipe hole right through the wall after screwing on a 3-inch-thick block of hole guide wood on the inside wall over a correctly located holed cardboard template stuck to the wall in the right place on the inside.
Then carefully put a correct sized pilot & core drill through from the inside using the screwed-on block guide plate. pop in all new solvent pipes & new compatible trap, then mortar in all holes inside & outside once it is all connected up, working and not leaking.
No silicone filling that shrinks and opens the cavity for me any more thank you, as he'd also done that on the kitchen sink, dishwasher, bath waste outlet pipes and the through the wall copper t sleeve on the incoming bottled gas pipe as well as using tubes of shrinking silicone on the hob to outside extractor fan pipe work (Another horror story told here in an on some five years ago.)
Once correctly filled inside & outside it made a massive difference to the winter heating oil bill , they must have made a cumulative hole size to the outside of about five inches in diameter.
As I have my disability probs all on my left side and in my spine, this is going to be a difficult and painful exercise to say the least, but I'm going to giver things a go.
Do any of you have any easier sensible solutions or suggestions that I can do myself ?
For after 17 years lots of crap work done by the locals from within a 40 mile radius, for some reason I don't trust these " Local tradesmen " anymore, plus it's very likely to be much cheaper.
Why?Gone up a few tyre sizes on the Jeep
Which means the spare wheel retainer no longer fits, straightened out the original clamp rod and moved the bend further along. Turned up a short threaded joiner and chopped the head off a bolt to extend it
New spare just fits, also had to modify the dog guard to move that forward, no pictures of that tho
New tyres are 265/75x16, these will do for now, ultimately its going to have 33" dia tyres, not sure how I'm going to fit 33" tyre in there though
Why?![]()
I love little wins like this especially when it saves you time fault finding on the next one!Another Honda PCX in today blowing Fuel Injection Fuse.
Seen it before (luckily for customer as first one took 6 hours or more to track down!).
Ironically it's the PCM loom guide that causes all the problems, time to chop it off and a bit of belt and braces with some radiator pipe and edge protector.
Probably 5th one now with same fault..
View attachment 373466 View attachment 373467 View attachment 373468 View attachment 373469 View attachment 373470
That Sharpie could do with a bit tlc.View attachment 373365
I got this today, tidy small hammour. A brass and a whit nylon head.
Head off. It was only fixed by a tin plated brass screw.
Shaft was dressed back to look better. There isa Broard Arrow stamp on the head and the brass face.
Looks like a small arms hammer.
Can't really complain its nearly 10 years old, just scary price compared to halogen.
