Gareth J
- North Cornwall
I couldn't justify an MCS install for either of our non FiT arrays either. Might come back to bite me if ever they pay fairly for exported units but not currently.I found some second hand unistrut, its 6m long, which I wanted, but double the width at 41 x 82 but it will do. It was cheap and delivered. 7 x 6m lengths in total, so good enough to cover most of the install.
I got chatting to a mate who installed my biomass boiler. He's MCS registered on the heating side and confirmed what I had discovered from chatting to others as follows.
You don't need the installation to be MCS registered to connect to the grid. Just by a competent person, i.e. a spark.
But the installation will need to comply with the relevant grid connection standards. In my case this is G98, so 16A max or 3.68kW, but there are others.
For G98 you can connect and notify the DNO, but for others like G99 you have to notify first.
If you want to get SEG, today's equivalent of the old FIT, i.e paying to export for the measly 5 to 7.5p per unit, then you need the install to be completed by MCS registered installers.
Same goes if you want the Tesla deal where you can get symmetric tariffs i.e. same price for import or export. The Tesla battery deal is something like 25p per unit in or out, there are deals if you have Tesla car too, I think you have to via Octopus, I'm still looking into this.
If you want to get 0% on the installation , then if has to be via an MCS registered company. The Sunak budget basically extended the existing 5% on renewables to 0% for a couple of years.
The 8 to 10 week lead time on the hybrid inverter I ordered turned out to be 2 weeks so should be arriving this week.
This accelerates things as I was betting on being able to cancel the order if I decided to go via the MCS route as I have a few enquiries in process.
Basically, unless the Tesla route proves compelling, the MCS path doesn't offer me much. As one of my major costs is heating hot water in summer via biomass then using solar to do this would compete with charging the 12.5kWh Tesla battery. Plus my intended 4 to 4.5kWp solar install is a bit small.
So, for me, a smaller battery plus a diverter to power the immersion heater would probably be the sweet spot, avoiding export to the grid, other than a last resort.
But I'll keep my mind open until the last decision point.
I currently have a few solar diverter widgets, it's quite easy to get one to cascade charging from one hot water immersion, to another or a night storage heater. Send me a message and I'll draw a schematic if that's of interest. Am also trying to figuring out/price up assembling some bits and pieces to create a customisable plug socket that works on the principal of;
IF; measured current (export/generation/whatever) exceeds a preset threshold, close a relay for Xminutes.
Such off the shelf things kind of exist but I'd like it all to work wirelessly, so I can move an enclosure, with a plug on one end and a socket the other around, within WiFi (or otherwise) range.
Should let me somewhat intelligently control things other than dumb immersions. Like a dehumidifier, a beer fridge, or, potentially, an AC unit, or a heat pump.
