prepman
- Gwynedd UK
You may have seen this already on the metal ones sold for corded drills with a standard 43mm collar, but they show a use case with the rods projecting though the base plate, which is useful for drilling a hole centred on a piece of timber (e.g. mortice a door).Which turned into this perpendicular drilling jig:
Brass soft jaws that go on some modified off-the-shelf soft jaws. See here:
https://www.mig-welding.co.uk/forum/threads/stuff-you-have-made-today.67127/post-2055213
I'm happy to share, but unless you have exactly the same monitor as me (HP E233) it'll be completely useless to you.
I found I've only ever needed two jigs , one for hard woods & one for soft , both are made from anodized Z shaped die drawn aluminium. IIRC one at 25 % and the other 30 % . As the z is used like a bench hook it's easy to use a marking knife to draw in the dovetails over divider made spacing points , once one set is cut simply use that as the template to make the dovetail angles on the other piece of wood .(I thought I'd already posted this, but perhaps not)... Anyway, a few days ago I made some saw jigs to help cut dovetails. I got a bit carried away and printed lots with all sorts of different angles:
They get held against the workpiece (behind it for a Japanese saw, in front for a Western saw) and they guide the saw:
or if you prefer a Western saw:
Once the tails are cut and the waste chopped out, the tail board is used to mark up the pin board and then the other two sides of the guide jig thing help cut the pins:
First attempt using the jig:
another one:
Link to the STLs: https://www.printables.com/model/199398-dovetail-saw-jigs-for-hand-cut-dovetails
Very nice print. What material?Dads underwater camera housing snapped its retaining clip.
So glued it back together to get some measurements and a quick cad later.
Got a basic test print.
View attachment 327681 View attachment 327682 View attachment 327683 View attachment 327684 View attachment 327685
Depends on what teabags you use.Thanks for actually acknowledging this valid point sir.
I've never read anyone state look at what my machine made today.
Plastic is not my cup of tea.
Interesting , would the cam lock lever device from scrapped quick change over bicycle wheel be any good for the clamp , IRC the spindle bolt is about 160 mm long , new ones cost about £9So I have a Dewalt mitre saw stand, which is easy to set up and take down.
Really quick to attach and remove the saw with the standard brackets.
So I figured its a really useful stand for All sorts of things.
I could just buy the Dewalt brackets, but at £65-70/ Pair I just can’t justify that.
So I designed and printed my own.
These screw on to the bottom surface and then they will just need a cam lever designing to move the sliding section in to lock.View attachment 347237View attachment 347238View attachment 347239View attachment 347240View attachment 347241
Within weeks, the ocean would be caressing her parted legs, washed up on some deserted island or in the belly of Moby dick.
I noticed in a later thread some of the couplers split asunderHe drew them up.
Could you redesign them with say an 8 mm thread running right through on all axis and screw in 8 mm stainless studding rod or do the same with 5 mm stainless threaded rods going into captive nuts at one end & use another nylock nut & flat washer at the other end to pull the axis into compression to stop it shearing off ?
Weld two two end to end or in a threaded sleeve so the cams are on the outside faces , I think that should give you almost 3/4 inch movement as well as ready made metal cam levers & nuts being a lot stronger than 3 D prints .This needs to move a greater distance to lock/unlock than possible with a QR skewer cam.
But I will be using the same principle
What’s a TPU?A protective TPU end in case I should accidentally fall backwards whilst pallet busting...again.
(That's CT1 to secure it btw).
