Your lad draw those or are they on thingi verse?A collection of simple PETG connectors for 25mm box section. Now done to enable me to build the basic frame over my veg patch. Nom 5.2m long, 2.6m wide and 2.3m high. Door detail tba. Can't decide whether to MIG one or make one with more connectors. It'll all probably need some diagonal bracing that I'll connect with rivnuts.
Yes it does^^ Does the sink drain into your 'foul water ' container?![]()
The white on the threads is a bit of grease More pics please can't quite understand set up. I've had leaks from above the extruder block when screw was loose. But you describe something different. Intrigued.A mess.
As much as I like the MicroSwiss direct drive all metal hotend, this happens far to often, and it eventually runs down the side of the hot end, and results in burnt filament getting dragged into the print.
I get get 5hrs 30mins with Prusaslicer. Cleaned the mesh up in Blender. Few zero faces in original.I would like to have made this but...can someone load this up and see how long it says it will take to print.
Its saying 1 day and 10 hours in cura 5
TV remote control holder by NiccceGary
Has a built in dock for a BYO switch controller charger.Feel free to post a photo if you print it and let me know if i can add or fix anything.www.thingiverse.com
