The_Yellow_Ardvark
https://www.death-clock.org/
- Going Away.
Only you would think along those lines.View attachment 351110a version of that![]()
I bet you wanted in painted in 50 shades of battle ship grey.
Black paint is not gonna be much of an insulator, it'll absorb heat from the cylinder and re-radiate it as infrared radiation (heat), which can then be absorbed by the air and taken away.
It's all pretty marginal stuff honestly, don't expect it to make a lick of difference in practical use... Just look nicer. Still tests have shown it makes engines cooler and it's done in racing. Which is in line with the physics parts.
Haven't yet fixed it! But everything is cleaned more or less and starting to get ready for reassembly.
Muffler got a coat of heat resistant paint. I think I will do the same to the cylinder that I media blasted the outside of. Since black objects radiates heat more effectively (they also absorb heat more effectively), that would make the cylinder fins work more effectively.
When I worked for Eaton, we made steering valves for thwaites dumpers, on ours the front seal end was removable via a snap ring making a seal change an easy 3 minute job.My Thwaites 2 ton dumper has been leaking for a long time from the 'steering valve'. It's not the original valve but one I rescued from a 'Bank Mower' that I scrapped. Same fittings and mountings but the swept volume doesn't match the steering ram resulting in MANY turns from lock to lock - but heck it works. The leak is from the upper central shaft seal and i annoying rather than debilitating. Slowly but surerly oil leaks into the steering column itself and back out as the column isn't sealed to it's mounting flange.
The proper solution is to strip the unit and replace the seal but life is too short and I'm still hoping to find a proper ex Thwaites dumper steering valve!
So today stripped out the unit from it's mountings, made a few measurements, I fired up autocad, draw up a flange gasket, ported the DXF to my laser cutter, cut a gasket, dragged out an old tube of Blue Hylomar and stuck it all back together.
Early days but so far no leak - I'll wait for the oil to come out of the top of the steering column but I don't think the leak is on the pressure side so it should only fill up to the level in the hydraulic reservoir !
Go to parts.jcb.com and put in the VIN number, you'll get the part number then. Invaluable I've found.When I can get through to the parts place to confirm the part number I'll order one up, but so far they're always on the phone
Hoping to get your stump ground tonight then?![]()
Yes I have my JCB 3CX registered on the JCB parts site can find part numbers that way, but I also have the 'user' parts book (which has pictures but only drawing refs no part numbers) and the 'workshop' parts book that has the lot. Mind yuo I tend to buy parts from Simon Vicary rather than JCB itself.Go to parts.jcb.com and put in the VIN number, you'll get the part number then. Invaluable I've found.
Looks like a Danfoss, the other main manufacturers were Ognibene and Rexroth, who bought out out Hydraulik Nord after the wall came down.Not sure what make this one is - I'll see if I can read it's plate with a mirror but location isn't ideal for this !
Be very nice if the seal CAN be easily changed.
Glad I'm not the only one suffering.![]()
It is 20 here already at 8.30am. I blame @Gragson as it is usually the chillier side of warm and I told him to bring a jumperA mild 31° with clear skies forecast today![]()
