The_Yellow_Ardvark
https://www.death-clock.org/
- Going Away.
This is one of the silly reasons I need to keep a eye on some members.
I spotted the issue before water and lemon juice was added.
You've done very well with that.........not today but last week......fixed these dents in an old Kawasaki bike exhaust using some air pressure and a blow torch
View attachment 350905View attachment 350906View attachment 350907View attachment 350908
About one and a half forum threads worthyeah I'm impressed too - how much air pressure?
About 8bar.......as much as my compressor can put out. Heat is less localised with plumbers blow lamp....bit more focused with oxy acetylene or propane, you can probably go lower...yeah I'm impressed too - how much air pressure?
Muffler got a coat of heat resistant paint. I think I will do the same to the cylinder that I media blasted the outside of. Since black objects radiates heat more effectively (they also absorb heat more effectively), that would make the cylinder fins work more effectively.
Only you would think along those lines.View attachment 351110a version of that![]()
Black paint is not gonna be much of an insulator, it'll absorb heat from the cylinder and re-radiate it as infrared radiation (heat), which can then be absorbed by the air and taken away.
It's all pretty marginal stuff honestly, don't expect it to make a lick of difference in practical use... Just look nicer. Still tests have shown it makes engines cooler and it's done in racing. Which is in line with the physics parts.
Haven't yet fixed it! But everything is cleaned more or less and starting to get ready for reassembly.
