The_Yellow_Ardvark
https://www.death-clock.org/
- Going Away.
This 1850(ish) plane came my way for £2. I got it as a restoration project, teaching project and they are a good tool.
Besides, I had already squired a full set of irons for such a plane.
It had sat in a wet/leaking shed for about 30 years. So after a quick clean to remove the mould. I left it to re season on top of a set of racking. Knowing it would take 12 to 16 weeks to stabilise.
Unfortunately some one, who thought they knew better, placed it on top of a boiler to dry out.
The results.
A full bodt split on the fence.
Plus a a split and warping of the main body.
Meaning it was not worth repairing back to full use.
But yesterday some member came round to see what could be done, plus learn a few more tricks.
Manu choccy Hob Nobs were eaten.
Cleaning was with a off the shelf wax and dirt remover. Meths. Will work just as well.
The weight of the dirt which re moved was 2 1/4 oz. They weighed it.
Don't ask me why.
The brass rubbing plate is worn. That we agreed was not an issue. As it was age related. But as the body is split the tool is of no use.
This is the finish with 4 coats of oil.
Finished, the split is visable, it has gone right through the body.
The oil soaked paper will be wraped round the plane and sealed in a plastic bag and left for 48 to 72 hours. It will allow the oil to soak in more. So it can be buffed up a lot more.
I should of seen this comming. I know I should of not left it down MIS, when I knew I was not avaiable for a few days.
It was Plane Sight.
