Parm
Respect The Sound System
- Towcester
Provide any links please?Have a search of London transport and the national bus company as well as anywhere with a big heavy goods fleet like Eddie Stobbart .
Some of the heavy lift tower cranes powered by massive engine driven generators were also on daily oil sample tests . Can't have 8 ton of load left hanging 150 foot in the air because the genny's engine has shed a shell bearing etc.
First time in30 years I’ve heard of an oil test for this purpose.
Someone invented this thing called fail safe
What brand of trials car ?. ( ex Liege owner)I'll not disagree.
Two of my engines are on carbs - my old Pug 106 on standard carb and my trials car running a 1600 xflow on an SU HIF - not had to go inside either for a while, but when I've had to, both were nice and clean. Crossflow valves were - I have the nice and clean head of one of the exhausts on my desk after I retrieved it from the sump after it hammered a hole in a piston when my mate, who borrowed the car, ignored the tapping noise coming from the engine . . .
I don’t know about in house labs but maintenance predictions using oil analysis is quite common.Is this supported by any evidence?
I think we use it for condition monitoring along with vibration analysis and other data to try and catch faults before they become catastrophic failures and do more damage to the equipment.I don’t know about in house labs but maintenance predictions using oil analysis is quite common.
My oil supplier offers it
One that beats Leiges . . . mostly . . . Mr. Lack beat me by fractions of a second on the Yorkshire Dales earlier in the month . .. tied on 5 (from the same restart)What brand of trials car ?. ( ex Liege owner)
I’ve seen this for big. Martin’s diesels but not busses and lorriesI don’t know about in house labs but maintenance predictions using oil analysis is quite common.
This is what I'm meaningTest Types - BES Group Asset Reliability
We are able to offer a wide variety of oil and lubricant analysis tests through our independent oil laboratory.pcmseng.co.uk
I’ve only personally had it done once and that was to check for glycol in transmission fluid as there was suspicion of some sort of osmosis going onI’ve seen this for big. Martin’s diesels but not busses and lorries
Standard sort of thing for industry, transport fleets etc - I just can work the relevance to tin pellets dangling in a tank doing nothing useful?
I did see one lot (might even be the brocket one) that claimed they worked in the presence of iron - ie the steel petrol tank . . . which should be interesting in plastic tanks . . .
Regarding the Hurricane claim - something on another forum made me smile - a reminder the gov wanted everyone to eat carrots at that time so you could see in the blackouts . . . a rather more believable claim as the contain Vitamin A, without which you can have eye problems . . .
Normal every day business in the shipping industry too. On large marine diesels you dont change the oil, just top it up and centrifuge.I’ve seen this for big. Martin’s diesels but not busses and lorries
Ah I never knew they used that to find out the bearings, Quite smart not sure why I didn't think of it myselfUse it on the turbine engines they can tell you which bearing is going to give trouble By different trace elements
Thanks for reply you obviously had a good drive. I'm sorry but I had to check results and was pleased to see that a liege won the class. Ray and Trevor are two long standing acquaintances of mine and can be very determined competitors. The best result I got ,in a very short 'career', was 2nd to Ray in the Allen trial a couple of years ago. Unfortunately I started car trials too late in life and found it a struggle to maintain the car , just old age . one thing I didn't like about the Liege was the lack of chassis behind the drivers seat which meant that everything was supported by the f/G tub. Have funOne that beats Leiges . . . mostly . . . Mr. Lack beat me by fractions of a second on the Yorkshire Dales earlier in the month . .. tied on 5 (from the same restart)
Class 7 Dutton.
A Class 8 Dutton under construction . . .
I like Lieges - I was a student when they appeared - remember giving the first one a serious coat of looking at when he had a stand at the kit-car show at Stafford county showground. I keep thinking what I could do with one to make it so much better at trialling - they always seem to be working so hard to get up a section I simply drove up. I do look every now and again, but with limited numbers built and the amount of pounds they go for when they do come up . . . I keep throwing my 500 quid (inc trailer) Dutton at the scenery
