I’m kind of 50/50 over the square tube, but there will probably be some panelling over the rear half of the frame eventually. I’ll have a transmission cooler back there, maybe various other necessary mechanical odd and sods too.Like the top tube lines. But square tube is a bit marmite. Will the engine come out again?
I definitely needed an interesting project to get my brain back on track.Good to see your mojo returning.
I did plan on fitting another round tube, instead of the square tubes, a bit like this mock-up. It needs torsional stiffness though, triangulation, to stop the whole thing winding up the rear half when/if I ever unleash 350 horsepower.Like the top tube lines. But square tube is a bit marmite. Will the engine come out again?
There is a slight angle in it as the Jag diff pinion is offset, so the motor is pushed across an inch at the rear, to line up, thus the U/J will always be ‘working‘ a bit.
big donut as a UJ. Not sure why
Gawd, I think my, possibly, 2° out of line joint is far closer to perfection than your average mass production, axle-strapped-to-leaf-springs, angle-varies-depending-on-how-much-junk-you-have-in-your-trunk, U/J installation.Gawd! I think I'm trying to teach my granny to suck eggs, but...
A single UJ (Hooke's joint) running at an angle isn't constant velocity: The output speed fluctuates at twice the input speed (worse as the angle gets bigger). It could start rattling a bit if it's coupled directly to the diff with nothing resilient in between. In a double UJ (like a conventional propshaft), if the joints are correctly aligned, the fluctuations cancel each other out and you get constant velocity transmission (provided the angles at each joint are equal - e.g. if the input and output shafts are parallel).
The rubber 'do-nut' joints suffer from pretty much the same thing, but being rubber, they damp out the torsional vibrations better.
Humblest apologies if you know this, but I didn't want to let it pass in case you didn't.
Following with interest!![]()
Sorry, no offence intended! - I suspected I might be trying to teach my grany to suck eggsGawd, I think my, possibly, 2° out of line joint is far closer to perfection than your average mass production, axle-strapped-to-leaf-springs, angle-varies-depending-on-how-much-junk-you-have-in-your-trunk, U/J installation.
No worries. Constructive criticism is always welcome.Sorry, no offence intended!![]()
I generally make so many mistakes when I do anything, it’s good to have people watching my back.
If i didnt have my boat project i would be doing one i reckon.
will be watching more cracking work
It’s a bucket list thing with me, been wanting to do it forever. It’ll have to go through MSVA etc, which entails trailering it higher and yon and various paperwork and inspections, so it may never see the road, but you never know.Why OH Why did i read this build, i have always wanted to build a trike again, well first didnt get finished. And a V8, just love themIf i didnt have my boat project i would be doing one i reckon.
Good luck with and luvin the project alreadywill be watching more cracking work
Thanks. New year, new me.So glad you have got your MoJo back here mate...really enjoying this thread![]()
Good to hear bud...more day light approaching soon,lifts my soul up as i hate the dark winters.Thanks. New year, new me.I’ve also been going to the gym 3 times a week for nigh on two months now. A bit of routine in ones life is good for the soul.
