25.4_mechanic
- Germany, southwest
If you take the chuck off what is the runout on the mandrel?
Will check in a sec ...
You can dial out runout with a 4 jaw chuck with independent jaws. It takes some skill and practice though.I had previously understood that only the repeatability of the three-jaw chuck was so poor, not the clamping accuracy per se.
Can I assume that I am reasonably correct with a centering four-jaw chuck?
Carsten
the same as any other 3 jaw chuck if your turning down metal. the 1st cut you make and your job will be accurate it just means you cant take it out of chuck and put it back in if needed you can only do that if you use an independent 4 jaw chuck and not a self centering one
build it back up and set the bed up using and turning a test barI get that one!
What do I do with the machine?
The only thing which would worry me is the "bed" edge of the bearing may be starting to pick up. Have a look at it closely, the bearing may be too tight, ref - your shim thickness figures. What does it spin like bolted up with no belt and no gear train?
I'm glad your mandrel is roundI don't know why I didn't think of this myself again ...
Measured like this, there was nothing to see on the hundredths clock, on the thousandths clock, the shaft runs within 1.5 thousandths.
Then quickly clamped my small self-centering four-jaw chuck:
Error halved compared to the three-jaw chuck!
What do I do now with the three-jaw chuck?
A proper independent Burnered - albeit nicely somewhat older - four-jaw chuck is on its way to me ....
- Bring the machine in balance?
- Leave the bearing as is, at most get the shims a little more homogeneous on a whetstone?
- Prepare the 1" test rod between tips?
- Waiting for the four-jaw chuck?
Anything else?
Thanks!
Carsten
We both feel the same way.I'm glad your mandrel is round
That sounds very knowing - yes, the joy was a little clouded lately.It seems like you are getting distracted by chasing accuracy and it's taking all the fun out of owning a lathe.
That's exactly the plan I have, I had already ordered the material for it on Saturday.Why not work through some of the projects in the Harold Hall book and get to know the lathes capabilities.
I then translated this into 9 S Mn 28 / 1.0715 and this is on its way to me in various dimensions.
It's just that it's easier soldering cleanSometimes I think.......yes, that's about it
Active recirculating cooling is currently not in the planning stage, but the tray was nevertheless necessary, if only because of the total-loss lubrication of the two main spindle bearings.
The amount of oil that remains to be absorbed after the chips have been vacuumed out is still within the range of what the blue workshop tissues are capable of absorbing - this should be even more successful now that the machine has been raised.
The tray has become so luxuriously large that it should be quite easy to install a drain at a later date - if, say, there is a milling machine with a built-in circulation pump to the right of it ...
Thank you for thinking of this!
Have a wonderful sunday all,
Carsten
If your using a piece of ground stock in a 3 jaw then you are effectively checking the 'true' of the three jaws. To check the spindle then you need a morse taper shaft. You can produce this yourself. Put an oversize bar for MT2 in the 3 jaw chuck. It doesn't matter if the 3 jaw is out or not, If if was running a 10mm off then it would be awkward. Remember it is the axis of spindle you are checking which the lathe produces no matter what the chuck does. If you put a piece of square bar in the 4 jaw chuck and put at 10mm to one side, providing there's enough 'meat' it will still end up with a shaft parallel to the axis of the spindle.I don't know why I didn't think of this myself again ...
Anything else?
Thanks!
Carsten
I think with this advice you hit the core quite well, I sometimes have to tell myself that.Just make sure you're not trying to exceed the manufacturer's accuracy
, so the break in style had to be done to measure electronically - but the trusty Shimpo is also a bit on the older side.If you can wait until later in the week, I'll check mine.
Do it by feel and gain experience. The bible on turning doesn't take into account the variable conditions of lathes. Use as reference. There so many variables, especially with insert tools.I think with this advice you hit the core quite well, I sometimes have to tell myself that.
The good Mister Hall also gives - quite rightly - speeds, an area that I had previously only dealt with according to feeling.
But how should I calculate cutting speeds without knowing the speeds of my machine ....?
Yesterday I wanted to get to the bottom of it:
The fully mechanical hand tachometer developed a nasty gear noise, so the break in style had to be done to measure electronically - but the trusty Shimpo is also a bit on the older side.
Have a successful day
Carsten
I can/will if you desperately need to know pitch, but.....
You have my dispensation, my son!
You need a point of reference.
you can see that it has to do something and if I wanted more I would have to use the new belt that is already here, but .....
I am very happy about this result - of course this is no substitute for a milling machine .....
