This is what I am saying,Switch 14 off. No pulse. Keep it simple.
Your machine is fixed frequency at 60hz when in ac mode, you can’t adjust this setting.This is what I am saying,
If you read Richards post,
Please verify what has been said/written/instructed.
Or :-
Is my Tig Welder set up/laid out, with a button missing !!!!
The Frequency Setting is an important part of the process I would assume.
Oh !!Your machine is fixed frequency at 60hz when in ac mode, you can’t adjust this setting.
 lolAs Daleyd saysThis is what I am saying,
Or :-
No idea if its a good machine or not, but Jasic in general are OK I think?Oh !!
Is that normal for this sort of machine,
Or have I bought a piece of crap.
Thank you for the updatelol
As above: fixed frequency.Is my Tig Welder set up/laid out, with a button missing !!!!
					www.jasic.co.uk
				I have the manual etc.As above: fixed frequency.
The manual is here:
JASIC TIG 200P Analog ACDC l PDF Documents
Jasic TIG 200P AC/DC Documents: Sales Leaflet - Operator Manual - MIG Welding Guide - Inverter Selection Guide.www.jasic.co.uk
Some aluminium you can. Some 1xxx and 5xxx series can be welded autogenously or with identical filler i.e. you can cut base metal and use it directly as the filler.You can't weld ali without filler, it will crack.
 I do these in work with no filler it depends on use adding filler slows the process down, material used to be 2mm but I made things harder for myself by agreeing to do it in 1.5, I'd prefer to have burn through but it is not wanted, any dirt on the edge that your welding and you end up with a hole these parts get powder coated,I have seen that on youtube videos. No cracking apparent. The ali is 6mm x 60mm angle of unknown properties. Probably was part of a carport or similar. For this job it was good enough. No issues. The angle was cut 45 at deg. So the corners were knife edges which fused back to form a nice bead.You can't weld ali without filler, it will crack.
From what I've read and experienced you're a little short on amps for Ali. It drags the heat away. At 120A I've found once I've got puddle going it's a race to finish (haven't got foot pedal). Don't like the pulse option, prefer to pulse manually. Also gone to pyrex stubby lens and 2.4mm 1.5% Lathanated (video he recommends 2.5%), The clear cup is a major improvement and the lens saves gas (£65 10ltrs)A learning day for me I have some old 2mm Ali to weld in some new Ali I have an old BOC ADR welder on no 2 up to 65A it will get the joint to melt and flow but my weld is to fat I would like it neater and a smaller fillet yes I do cock up but learning what size of rod I have 2 mm on the shelf also what tungsten and shield to try and get it all neater is to dam ugly a weld so far I am better at gas welding it but I want to improve my tig welding and today is the day.
Andy
As I am working with old Ali my prep is a s/steel wire brush still have a bulky weld been trying what I have read on here all ten pages LOL.
 I've been TIG welding for about 20yrs and MIG for 30yrs, but ali is a different beast. Gas welding 50yrs back. All DIY use. First AC set for me. I use the https://www.ebay.co.uk/itm/202472264757 for cleaning surfaces, doesn't clog.Good article. One thing I was aware of is 'hot shortness' which weldintipsandtricks discusses.Some aluminium you can. Some 1xxx and 5xxx series can be welded autogenously or with identical filler i.e. you can cut base metal and use it directly as the filler.
Many grades of aluminium become crack sensitive due to the proportion of alloying elements which come out of solution.
Most commonly magnesium and silicon, on cooling that combine to form Mg2Si.
