Seadog
Save the planet. It's the only one with rum!
- NE London - UK
There's an issue with multiple belts. Because of slight differnces in length they don't all drive evenly.
I believe that you can buy matched sets.
I tried that on my Triumph. Belts all different. Took 2 off leaving just the 1 belt. Made no difference.Will have to test mine with a tub of water and see if it is anything like yours.
Regarding the belts, supposedly if you mark across them with chalk or similar then run a while then stop and rotate by hand to find the marks and see if they still align, if they do the belts match, never tried myself.
^ that's what I said. Too easy to make assumptions....Have you tried removing and replacing the chuck? Or using a different one?
It is a known issue, http://www.lathes.co.uk/colchester/page3.htmlThat's a big assumption to make. I would take the chuck off to try it - put the small drive plate on. If the vibration is still there try a lower gear, same motor rpm. If the vibration is still there then @prepman is probably right.
I was brave once and tried a very heavy cut - heard the motor working for a living. Chips flying everywhere and a nice finish - must have been a 1/4" cut - lathe just laughed it off.Compressors are very different to a lathe, in that the load is not constant - quite the opposite in fact. so the belts will be having a hard time, all the time.
My truimph has the motor on a tilting plate, I'm not even sure it's tightened, and I've mot managed to make the belts slip yet. Obviously cuts too light....
Nice machine and nice price. I notice it has the early feed lever system? Where you slide across to change feed axis. Word of caution if it is. Be careful we re-engaging the drive that it is still in the same postion and hasn't slid across. I found out the hard way.Well just won my bid on eBay and very happy with my purchase, Seller states 1964 Colchester triumph 30" between centres with a 15" swing and 2" hollow centre
View attachment 315293View attachment 315295
21" faceplate, then 14" and 8" along with the travelling steady ,12" 4 jaw and 10" 3 jaw fitted to machine and some drive dogs along with carbide insert tooling centres and chucks.
Also comes fitted with a rapid screwcutting box which I thought it meant it cut the threads physically faster
Only ever worked on my small new mini lathe at home and a brand new Colchester student for apprenticeship training so will be interesting learning about this.
Now just waiting on getting it home and building a three-phase power supply for it, thanks to @fizzy for helping me figure out how it can be palletized
happy with my purchase think it was a good deal and look forward to making some chips on it![]()
There's an issue with multiple belts. Because of slight differnces in length they don't all drive evenly. There's details somewhere on the net. My Student has one wide flat belt.
Hi sorry reading back my message posted a bit late I did not make it clear that the video was filmed with just one belt ,, I put it in the youtube title but not forum whoops. As you say I have heard of this belts issue before so I ran the lathe with just one and found the exact same problems as I had with 3 belts so I am quite happy with the state of the belts and their matching set due to little change when ran at just one belt.It is a known issue, http://www.lathes.co.uk/colchester/page3.html
The drive from motor to headstock was by 3 V belts that should, when replaced, be exactly matched for length; if the geared headstock on any Colchester is unacceptably noisy, especially with rattles rather than whines, the cause may be unequal-length drive belts "fighting" each other, cau.......
, but only a possibilty not a definitive answer.
As you quite rightly say it could be other issues, inbalance in chuck, timkin (sic) bearing (sincerely hope not), gearbox or the motor it's self.
I know that a certain industrial compressor had 6 vee belts and was always shredding them. Never gave it much thought, mainly because it wasn't my problem. But like a lot of things as you get older you come across answers to questions from way back. Me and Methuselah often discussed it.
Nice machine and nice price. I notice it has the early feed lever system? Where you slide across to change feed axis. Word of caution if it is. Be careful we re-engaging the drive that it is still in the same postion and hasn't slid across. I found out the hard way.They changed it to a safety lever later on.
All the feed lever needs is a gravity drop down gate. Thought of making one when I had the apron off. But now I just double check. Mine was fitted with a safety clutch on shaft, unfortunately set to high. When it goes into heavy load it's almost impossible to disengage the lever. It just carries on until switched off. I intend to readjust it. But slight technical issue to pull the feed shaft out (pic) Involves a farm jackAlso I have been having some issues with lines in the finish so this could be what is causing it vibrations in the tool maybe but it also could be separate and just down to wear and other things , It is a 50 yr old machine after all
Yes that is it , slide across for sliding turning or surfacing. Easy way to ruin a part slamming a tool into a part on surfacing mode when meant to take a few thous off.
Have you tried running without the chuck in place ?, try putting a longish bar in the chuck ,set up a dial indicator on the chuck or the bar in the chuck and pull and push on the bar to see if there is any movement ..Got a few bits sorted on the triumph over the holidays
Oil changed in the headstock and screwcutting gearbox
For some reason all my text is changing to italics now
Little bit of glitter sitting there but not too worried about it no idea how many years it has accumulated that over
Also had a shot at sorting out these resonance and vibrations seeing if unmatching belts caused the issue but it was not as one belt ran them just fine and all the belts have unique matching marks so I imagine they where a matched set
here is lines in finish with 3 belts that remained unchanged as the vibrations did when it was taken to one belt
Intresting however , When the belts where loose the vibrations where a lot lower IIRC
A quick vid of vibrations and a weird resonance at about 1000 RPM shown by my handy RPM sensor , These vibrations make it impossible to read dial guages etc when you are near resonance RPM unfortunately however the lathe was never geared to run at 1000RPM but the non two-speed ones were so quite confusing.
Think thats all to report may have more to add in the morning.
I do have those tools which make finer lines but still not ideal lol , Easier to show on the heavier cut tool.I had the lines - you need those tools I linked to!
I found around 400 to 600 rpm with the finest cut gets rid of them. That or a 1/4" cut with a cnmg or similar![]()
