My Old Landy
Engineering Mayhem
- North Lincs
I know, but I am on a three minute time ban not the luxury of ten minutes like you 250 sub types!Quality not quantity mate.
Why extend the scales putting some brass or copper rivets in the two hole & rivet them in tight to fill the holes then grind back & and polish the scales & the heads flat to make it an unusual feature . I feel it would look good if the scales were 3 mm past the holes going along the bladeMust be something in the air....
Yesterday evening decided to finish off some no spin throwing knives that have been kicking about for a while now.
They are cut out of "annealed" quarter inch truck spring.
Being quarter of an inch thick (!) they need some substantial lightening holes in the handle for balance and to stop them sinking an inch deep in the target board.
It was a disaster! They are not fully annealed and my spurious collection of random drill bits won't touch it. It may be work hardening but on one occasion I ended up with a huge dimple pressed through one side where the drill bit just wouldn't bite. So I chucked it in the forge and punched the holes through with a drift. Yeah, ugly as sin and I'll have to open up the holes with a cutting disk. The other three blanks went into the forge, red hot and two left in there to anneal, one dipped in a bucket of vermiculite.
While I was doing that, it occurred to me I better finish this off so that I can claim it to be my first knife. Heat treated, O1 toolsteel, quenched in chip fat oil. Still arrow straight.
It is a copy of a Gough custom because I just love the look of the blade. It went glass hard so tempered in the oven at gas mark 6.
Reason I lost interest in this blade is I have two "precision" holes for fixing the scales and a load of "random" lightening holes.
...I stoopidly drilled two random holes right in front of the handle where it will show unless I extend the scales to cover them up which will make it look "bulky".
I'll do it anyway, not exactly an EDC anyway, no one's going to see it except you guys.
When you ground the blade was it a dry band machine or a wet sand stone wheel?
Obviously nowadays there's all new fangled ways of hardening & tempering ways for different grades of steel & steel alloy's but for decent pre 1970's leaf spring chisels & knives it still very good .
Just checked on what I was thinking when you said what you were going to use for handles , all parts of laburnum including laburnum wood is poisonous .. so perhaps a bit of a no no for a knife handle that may give you splinters or lay on wet foods etc. " Is laburnum wood poisonous ? - Bing "Well it may be "new fangled" but I always take my materials up to critical temperature before quench. For the O1 toolsteel above, I took it to bright orange and kept it there for as long as I could stand the heat, then quench immediately in chip oil. I would use new fangled quenching oil but I am way too tight to even consider it.
Then temper in the oven at gas mk6 along with pizza (which was nice). Was aiming for a straw temper and hit it too.
Scales came from my garden a year or so ago and have been resting in the house. They will go on raw and if they crack or split, I'll make some proper ones. I think these may be Laburnum.
Made up a sanding block from a bit of fencepost and a chopped up sanding belt.
Bags I first trawl through your gear when you've snuffed if from Laburnum poisoning from the knife handle on your wet skin . PM me I'll let you have my contact details for your will .That is why I want to use it, I discovered it is poisonous after I chopped a bit of it down. However, I am not going to eat it so I think I'll be safe.
The blade and handle are top quality superb.New tanto finished today
Super pleased with the handle. It's actually old oak looting cut up into blocks and glued together, then cut in half on the bandsaw, brass pins then hand sanded to 600g and I I shed with linseed oil. I love the end grain.
maybe Martempering would do it......ideally though you need to know the grade of steelNext step is to up my game a bit, so I have been experimenting with the san mai technique. This is mild steel outer layers and leaf spring core. It forge welded up perfectly as you can see where the steels welded in he photo but when I quenched it developed a huge shear right down the middle of the spine. Not on the weld, right through the core of the leaf spring. I've read this is because as it is quenched the carbon steel expands and because it has nowhere to go it shears itself. An edge quench is supposed to cure this.
I thought I would grind it and finish the blade just to see how it comes out and this is it after 2x20 minute etched in ferric chloride. I'm trying a coffee etch now.
I had seen something about ghat but not read into it, that's a good link, thanks. I still have half of the billet left so I will try that when I next have a chance.maybe Martempering would do it......ideally though you need to know the grade of steel
Martempering/Marquenching - Hardening and tempering - Bodycote Plc
Interrupted quenching of steels typically in a molten salt bath, at a temperature just above the martensitic phase. The purpose is to delay the cooling for a length of time to equalise the temperature throughout the piece. This will minimise distortion, cracking and residual stress.www.bodycote.com
Any time before I quench I do at least three normalising cycles, more if I have been forge welding. I made an axe which I have posted before which was exactly this combination, mild steel outer with leaf spring bit, it heat treated perfectly but I did only do an edge quench.Another technique for reducing the possibility of splitting would be to do a couple of normalising cycles. Take the whole thing up to a good red heat (after searching for some recommended temperatures from the obvious sources) then just let it air cool. Another tip would be to heat the quenching oil before you lob it in there.
Not so sure about preheating the oil, my understanding is this gives a faster quench and in this case effectively I would be better with a slower quench.
