Not all today but I finished it today.
I started with this (it cost me £5.00 from an auction - nobody wanted it and the auctioneer started at a tenner and went down, I chipped in with a fiver expecting it to start but nobody else bit and I got it.) :-
View attachment 290548View attachment 290549
It went through this :-
View attachment 290562View attachment 290563
Also a belt linisher to clean the blades up and a lick of paint on the small parts and the body :-
View attachment 290564View attachment 290566
To end up with this :-
View attachment 290568View attachment 290569
After a bit of tweaking of the blade clearance I was well pleased with how it cut some test pieces :-
The red is 1.5mm, the next blue is part of an old up and over garage door that you can see the shear was working as a brake/folder - this was the 'before' picture and the four bottom bits are some of the same door after the rebuild when I was testing blade clearance.
Now if only I could get it to switch between shear/folder mode automatically
You can still buy these - they're about £100 inc. VAT - I don't know if they are exactly the same - this was all Whitworth threading, I suspect the current model will be using metric. The bolts were well worn and I probably should have gone and bought new but that's a project for another day.
Fished a couple out of skips a while ago. Flogged one, kept the other. Someone had bodge welded a length of across the underside so it can be clamped in a vice to use - which does make it easy to get out and use, then put back out of the way.Looks near-identical to the Peddinghaus I have; it was leaning against a skip and I asked if I could have it... Superman couldn't have opened and closed the van doors quicker![]()
Bodged a chair repair as i couldn't get it too split apart and the 'low' setting was pants !
looking goodFinally got round to fitting the woodworking vice that I got from @roblane65 . Before:
An hour later after 2 pots of tea and much sawing, chiselling, and violent swearing:
Have to have a trip to the great metropolis tomorrow as I'm out of suitable screws, then crack on and make some wooden jaws.
Sealed bearings don’t last 5 minutesNot really fixed but fixing because they sent out the wrong bearings ,resume on Monday .
267 × 200
Chipper bearings gone at 500 hours so going to convert them to greaseable.
View attachment 291612View attachment 291610
edit: well 30,000 minutes lol
267 × 200
This is one the same I converted in 2016 to greasable, not been a moments trouble. Removed the shaft for inspection today![]()
Anything in the manual suggesting when they ought to be replaced?
Regular greasing, like old cars (ie 1920, 30 etc), forces out the crap that gets in, pushes old contaminated grease out.
We try and design for 50,000 hrs between major maintenance - on major bought in design on a project I was was on a couple of years ago, theory said we'd get 38. Management said that might be okay . . . No, I said, 38 hours! Not 38,000 hrs! Took a year to redesign to get theory up high enough to be worth doing.
I'm a big fan of regreasable bearings, and are definitely better in a lot of cases, problem is that the guy with the grease gun needs to know what he's doing. depends on bearing type and installation. Too much grease is often just as bad as not enough...
Had a back to back offshore years ago, could always tell when he'd greased a fan bearing, they were running mad hot, old style plummer blocks with top caps, he pumped in grease until it was full everywhere. Always the same solution, shut everything down, remove about 1/3 of the grease, back to normal running temperature again. He must have been told a hundred times, manufacturers lube schedule called for a block 2/3 full, then 6 monthly add a couple of shots, but he just couldn't (wouldn't) get his head round it....
Nothing in any of the service/user manuals, typical use with standard bearings would be about 750 hours. Feeding them with sweepings, fencing wire and running blunt knives doesn't help.
May be the case with bearings running in a controlled environment, for any kit we run the "over grease" as @bricol says is the only thing pumping out the contaminated grease/grit out of bearings/bushes. The 500 hours the standard sealed bearing ran to vs the 2000+ hours of the greasable conversion sort of proves the point considering its a back to back comparison of the same machine doing the same job. All I have done here is remove the inner seals from the sealed bearings and installed a grease nipple in the centre of the hub so the hub acts as a big grease reservoir.
Bob
Bob
in our case it caused over heating as it had nowhere to go.
