You could use a piece of 2-3mm plate to bend it over, to keep the gap uniform with the originalHonestly I was going to skip it I kind of had it in my head that the lip doubled over on itself is just asking to rust later (although the rest of the shield will probably go first.)
I might get the vice grips and fold it over.
Hahaha... One of the dangers of posting your work on here lolWhat I hear is .... Dan quit being lazy![]()
What I did deep was drill through the floor pannel itself woops.... No idea how I would be supposed to plug weld now of I was planning to put this back on the piece I removed it from?
Gonna try copy the Japanese dudes video and try to fab this in sections with realistic bends that I (think) I can manage.
Once you see the below you're gonna say why take up welding because my calling is clearly art...
But in thinking bottom sheet can be made from a single piece,
Top piece the blue and then the yellow the side panel.
Do you mean this:I was going to ask if I could skip element's of the fork up the top but this is for the jacking point so I assume this to probably add more strength to the floor and rigidity to the overall piece. So I'm gonna try keep these in.
@Myles1970 how did you add the dipped section to the floor pannel you did? I'd like to try replicate that dimple in the top middle piece just below that fork.
