Hood
I am obsessed.
- Carnoustie, Scotland
Aye, I knowno need just winding you up
yes please can we have the link again? I dont have much luck with parting tools/inserts
Doing a wee job for someone today and was parting some harder steel so took a vid.
Having to go a wee bit slower with this one.
52mm OD and I think it is EN8
I can never get mine to cut stock over 20mm like thatDoing a wee job for someone today and was parting some harder steel so took a vid.
Most parting tools want to be on centre although I used to use some Kennametal ones that worked best at 0.1mm above.Very nice.
Some questions for you.
Do you set the tool to be bang on centre height - or higher or lower?
What cutting fluid. Looks nicer than soluble oil.
What lathe is it?
And finally what rpm?
I am still struggling with arm and getting the feed fast enough to stop chatter
I am still strugging with arm and getting the feed fast enough to stop chatter, but I got it down to about 6 seconds at 1400rpm
They are in this months MSC flyer.@Hood where is the link you posted, in this thread?
oh no now I got to spend some £££They are in this months MSC flyer.
https://edition.pagesuite.com/html5...me=&edid=0848f590-6fed-4ba3-a032-b8aaa9db668b
If you use the code ADVFREE at checkout you should get free postage.
You don't have to, but if you do I think you will be happy with it, certainly the best parting tool I have ever used.oh no now I got to spend some £££
oh I do the cheap bangood one is pretty carp the tips dont fit snug and break easyYou don't have to, but if you do I think you will be happy with it, certainly the best parting tool I have ever used.
If you mean the block then yes it will unless the block is non-standard.I wonder if it will fit in my parting tool holder probably not.
Yes not sure if my other tool was 19mm blade ill soon find outIf you mean the block then yes it will unless the block is non-standard.
