Dieselman 63
Forklift Certified
- Wellington, New Zealand
Aye. Being collected Saturday.
Still have the L but that will probably go once I've put it back together.
A new lathe on the horizon or is that it?
He's downsizing, Have you not seen most of @eLuSiVeMiTe recent for sale threads?A new lathe on the horizon or is that it?
By all means Brian. Nice to keep the continuity.I am the proud new owner and if @eLuSiVeMiTe does not mind, I will keep the thread updated once I get her back together again!
Cheers! I have got the motor out and my other brother in law is going to weld it as he's has stick and the skillJust found this tucked under a folder.
Ping me your details and il pop in into the post at some point next week.
Goes inside the changewheel door.
Wouldn't weld?Well after the fiasco of trying to get the motor mount welded, I fixed it with a couple of bolted on straps. The motor is now installed and the lathe is in place.
I have had to order some imperial Allen keys as I don't have any!
It was more of a case of didn't want the hassle. I tried a local engineering company too but they wouldn't touch it either.Wouldn't weld?
Shouldn't take long to get the rest back on now and get turning.
Was only wondering if it was built yesterday
It all went together really well. I was impressed with the head stock fixings, I just need to work out how to run the VFD, as I don't think 770 rpm is going to work for everything!Excellent. Did the saddle bolts go in ok. Remember them being a nightmare
Cheers, that will be fantastic. What oil did you use in the head? I oiled the gears with 3 in 1 as I don't have anything else at the moment!!Whoops. Just seen the oic of the changewheel chart. Still on the shelf in the garage. Will sort that tomorrow.
Iso 32 on everything.Cheers, that will be fantastic. What oil did you use in the head? I oiled the gears with 3 in 1 as I don't have anything else at the moment!!
Cheers, I will get some inIso 32 on everything.
