Today I machined another tipping wheel for the bead roller.
I have an earlier version that I welded and then machined (because I didn't have a big enough lump of bar) and that works fine.
This is for a mate but I might make one for myself as well.
It's made from a bit of tie-bar that came out of a harbour wall we were demolishing, I'm sure 20 years ago.
It was too big to fit in my 3 jaw and I should have put it in the little 4 jaw but instead I tack welded a bit of bar to it and mounted it in the chuck that way.
When I machined the first side down I was able to turn it and mount it in the chuck then use a parting tool to cut the bar off.
It didn't like it and broke the parting tool tip.
The heat affected zone was a hard as the hobs so there must be a bit of carbon in the bar.
This is good (I think) as I might have a go at hardening the whole thing.
The bar had hardened to a fair depth and was still hard 3mm in.
The rest went fine and I did clock it in the 4 jaw to finish off the other side.
Very simple thing but I'm quite pleased with it as it's about the level my machining skills have reached.
Has anyone any idea what grade steel a 70 year old 3 inch tie-bar would be made from?
Nice tip @Hopefuldave I will be using the tailstock for a bit more rigidity next time I am torturing the Drummond.Until you add support on the vertical... Bring the tailstock up and lock it against the back of the milling slide for the cut, helps add a bit of rigidity and you'll get a more consistent milling cut with a better finish - I used to do that (had topslide on a big angle plate bolted to the cross-slide tee slots) before I got my milling machine, it made milling on the lathe a bit less unpleasant!
Dave H. (the other one)
Balls! looks almost finished too, Gutting when that happens.![]()
Well thats going in the bin. I made several mistakes. The biggest was I engaged the dial at two, where as the rest of cuts were at one.
I'll get some practise on scrap before I try this again..
Is it a metric leadscrew on the lathe? If not then it may be that you should keep the halfnuts engaged until the thread is complete.
Feel your pain. Had the same happen to me a while back. Now I choose a number on the thread dial and stick with it. Takes longer as you always have to wait for it come round. Better than trashing the part though.
