@Munkul
Can you tell me make an model of your black angle grinder?
I have one which was of a friend of mine who unfortunately is dead.
I can't find the parts I need to repair it
ThanksIts an Elu, 800w IIRC
Its an Elu 800w paddle switch, I THINK its a WS12. It's done more work than any grinder I've ever seen, it was bought second hand about 20 years ago and the cutting disc spigots are worn smooth![]()
thanks
I made a build thread on WW for it, unfortunately used photobucket at the time.
https://www.weldingweb.com/forum/we...t-equipment-and-gear/147890-new-welding-table
1.25m x 2.5m x 20mm top
100mm hole spacing 16dia holes
You always want biggerHow do you find the size of the table, do you wish it was bigger sometimes. I can't decide whether to go for 8 x 4 or 10 x 5. It's just the bigger one will take up more space when it's not being used which could be months at a time.
I think it's a very usable size as-is, it's great for jigging up things like trestle legs and stuff that actually warrants a flat surface. If you were making gates or something, then bigger would be nicer.You always want biggerI think it's a very usable size as-is, it's great for jigging up things like trestle legs and stuff that actually warrants a flat surface. If you were making gates or something, then bigger would be nicer.
It depends if you want jig holes or not.I think I will go for 10 x 5, would 15mm thick be enough with four 10ft lengths of 160mm channel iron underneath it
The 20mm plate on mine is great, but several of the most used 16mm holes are getting a little bit loose... it's only S275 plate, not super hard or tough, and it will give a little. A thinner plate will give even more.
I wonder if a 20mm hole system would be better in that regard.
Refurbish lathe, bigger guillotine, bigger pressbrake, etc etc. As it stands, we have both TIG sets on the go atm - the IFL for tacking frames, and the Lorch for welding out.
That’s pretty cool where did you find that? (The cupboard)It's been a few weeks.... been a busy boy.
Cleaned up and moved the rollers
and I fitted an LED strip around the doorframe of my cupboard, on a microswitch connected to the door.
Still have to get it wired through the back and into a handy socket, though!
I got a job lot of 4 sections from work for free, they comprised a pair of walk-through electrical control cabinets from the 70's, doors at each end. I built one into that cupboard, my brother built another into a cupboard for himself, and I gave away the other 2 sections! They are huge clumsy things with sides made of 4mm steel!That’s pretty cool where did you find that? (The cupboard)
