slim_boy_fat
- Scottish Highlands
Assuming that's a rifle in the slip cover, are you acting as Security.....?
Block of wood in the vice on the welding table by the door with stick-on targets
At least it's not directly inside the workshop.
Not sure why everything looks tiny in the pics! all the equipment looks like toys![]()
- just don't tell me I have missed it
put a bit of wood under it....Nice work mate.
You can buy different length rams for those chairs about a tenner each. They are universal fitting and just knock out of the taper. That would solve both the sinking and the too short problem.
Mezzanine outer beams fitted at the weekend
Got our design engineer at work to design the outer loadbearing beams, and designed the rest of it myself. Some of it is common sense and experience - overspeccing beams for short spans is very easy.Do you design the steel work for the mezzanine yourself and get it checked by an engineer, or did you get an engineer to design it? Curious about the process.
That's a great workshop, but it can't be complete; there's no kettle, microwave or hob!![]()
The kettle and microwave will be coming....! At the moment they're just a walk away, lolNice work, but what type of tube bender did you use to make these bends?Started making handrail standards for the stairs last night...bodgedcut the elongated areas with plasma... thankfully will be welded up so won't see my shaky hand
It's been a long time since I've had to make handrail returns... I was amazed when the first one turned out right!
Just a cheap ebay tube bender and a bit of oxy-propane heat to "finesse" the anglesNice work, but what type of tube bender did you use to make these bends?
Cheers for thatJust a cheap ebay tube bender and a bit of oxy-propane heat to "finesse" the angles![]()
Thank youhydraulic.
