I'll have to check mine and see if they changed the setup on later models. If not then I guess I've got another project to get some oil into my ones ways.
Z axis nut is all bored and threaded.
I had to knock up a quick & dirty boring holder for the insert. It wasn't great but it did the job and held up fine.
That's nearly it for the screw I have to turn the plain end down to .750", make a woodruff cutter to cut the key and then drill & tap the end for the securing bolt. I might just cut a straight keyway in it I don't see what harm it would do.
I bought the inserts from eBay, have 8 and 10tpi LH. I could let you havean insert if you need one Ronan though I'm unsure if it'll so down the bore of the nut.
Your machine is an absolute sumbitch to do the cross slide nut on by the way. I had one that was badly worn and the nut & screw had been carrying the cross table weight.
BTW You could look at this list for your thread size see if it's listed. The platform nuts are a lot cheaper than you're quoted.
https://www.mcmaster.com/acme-nuts
RDG tools have a large selection of Acme taps. Prices aren’t daft either. Use it sell it on.
I've been watching them, 5/8 8tpi left-hand have been permanently out of stock since I started looking 4 years ago... Must be popular?
Dave H. (the other one)
They’re impressively low qualityI've been watching them, 5/8 8tpi left-hand have been permanently out of stock since I started looking 4 years ago... Must be popular?
Rdg , a more expensive lower quality version of bang goodLike a lot of rdg's products.
Rather just single point turn one. Actually that is exactly what i do!
