selectedgrub
- New Zealand
What is a burke bar? They look to be over engineered
What are those leaf spring off ?
I’ve got some here from an articulated lorry, not sure if from the trailer or tractor unit.
They are about 20mm thick and nearly 1.5 m long
20mm! Eek. Good luck with that! Half inch was bad enough, it takes a TON of energy to get it up to temperature. A small section of that would make a decent axe or hatchet. You may find it has a taper to it but I am struggling to think what you'd make out of such a massive lump pf spring steel.
I had to update my forge just for the half inch stuff (will update the relevant post).
It took long enough to cut a bit with the big grinder
You should definitely be making yourself a Burke Bar... Trust me, you'd love it.
Tell me what you did to break out the grinder maybe is easy to repairI'd happily swap you a chunk of 10mm leaf spring (see above) or some car coil spring for some of that unfeasibly thick leaf spring.
Incidentally, I thought I'd break out the 9 inch grinder to make the cut but tbh, the 4.5 inch with a thin cutting disk did a great job. never mind the broken one, that was my stupid fault.
I think that is possible reduce the volume of dead space into the forge using formiculite (I don't know if is the right term ,here in Italy call it this way) that is a good insulation material .20mm! Eek. Good luck with that! Half inch was bad enough, it takes a TON of energy to get it up to temperature. A small section of that would make a decent axe or hatchet. You may find it has a taper to it but I am struggling to think what you'd make out of such a massive lump pf spring steel.
Wrapping the piece with this material and leaving the part which will be bent exposed to the forge burner
Before to take out to bend it under the press,if you have a OA rig you put an heating nozzle ,ignite the torch and point onto the piece
Take It out and bend it , after that it needs to be tempered
I know what you mean ,I have a Bosch GWS 18-230 if I can use something different ... I use something different.To "break out" in this case means to retrieve it from storage. It is a perfectly good example of a 9 inch grinder though given the choice, I would always prefer to use something else (anything else!). Those big grinders are an accident looking for somewhere to happen.
I always use any kind of grinder with both hands and safety guard installedI use 9" grinders every day of my life as well as 4.5" ones and I would say the 4.5" ones are more likely to cause injuries than the 9" ones. Yes the bigger ones have more potential to do greater damage to the body but due to their size they require two handed operation and personally I think they are safer.
Is that you putting your feet up for a few days?Another very similar problem "popped up" in an awkward space between my boundary "fence" and the neighbours.
Sycamores don't hang about and in no time at all can become a serious issue.
There was another one taking off right next to a concrete boundary post. Access was limited!
Sycamore Forest 0: Burk Bar United 3.
I cut this down to 56 inches but am beginning to wish I hadn't. I don't have enough weight to trouble either end of this device. It could easily accept a few more feet of leverage. Those Sycamore roots are as tough as old boots and they demand a huge amount of effort if you need to literally rip them out without digging or wiggling. It's great for stabbing into the ground and letting the angled end burrow its way under the target. I'm still thinking about making another dead straight version, next time even sharper!
Is that you putting your feet up for a few days?![]()
