slim_boy_fat
- Scottish Highlands
Even seen some quite novel solutions to have a fag while wearing the respirator
Don’t know about masterclass but happy to share what I know.
From previous experience it’s always got complicated when things are on open forum.
There are three broad groups of substances that folk of the forum often use, these are dicloromethane (paint stripper, highly effective and very good but quickly fatal in the wrong hands / circumstances, usually causes harm very quickly. epoxy based paints (again very good at what they do but precautions required as they are potent skin sensitisers and implicated in occupational asthma. Any isocyanate containing paints (again very good products but also highly potent respiratory sensitisers that cause occupational asthma)
DCM isn’t a chronic hazard, that’s to say it’s effect is usually quick and often fatal
With the two paints, there is no smell or taste or any other tell tale indicators that exposure is occurring. It’s best to think any disease caused is invisible. By the time you start exhibiting any symptoms it’s usually too late as the damage is irreversible. There is no cure.
A little tale.
Few years ago I was asked to look at Europe’s largest accident repair workshop, it’s in Scotland. A young lad of 18 was training to be a paint sprayer, occupational health surveillance picked up he had work related asthma, so an investigation ensued where I was involved. Company were top notch and going above and beyond what was required, no problems identified.
So I expanded the investigation and took a more wider look at the lad and considered interests and hobbies outside work. Turns out that from about the age of 16 he was being guided by his uncle in learning stuff about cars, nothing out of the ordinary here. However the uncle had a poor attitude about doing things correctly and just told the lad to crack on, which he did, without the correct precautions in a home workshop. I inspected the workshop, typical garage at the back of a house in a medium sized estate. No control measures.
The young lad has severe occupational asthma as a result of being exposed to 2K paints at home. At the time his prognosis was that he will probably never work. A very tragic situation that could have so easily been prevented.
Any reputable paint supplier will always (should always) advise that 2k paints are for professional use only, this implies that correct control measures should be employed .
It drives me nuts when people give incorrect advice with little knowledge. It’s not fun having to speak to folk that have been hurt.
So the short of it is, if you wanna work with 2K spray paints, and I guess rolling or brushing too, you gotta have a fresh air mask?
And the mask has to get the air from some remote source, not good enough to have one of those respirators hooked on your belt I guess, as it will just suck in the same contaminated air.
I’ve used 2K only ever for lacquer. I use the following technique:
Hold breath
Spray
Run away.
Ha ha! The 2k lays on like an absolute dream even if I am running the air pressure far too low. It’s only the base I have issue with. The clear as fantastic as it is don’t hide the bad base. The 1K RFU clear would probably go on a lot smoother with the air pressure whacked up.This might be why you are not getting the finish you want on your BMW
Does anyone have any general guidance on the likelihood of an explosion caused by solvents and light fixtures?
I have purchased IP65 weather / vapour proof LED fixtures and will have sealed conduit protecting the wiring going into the fixture. If I have a well vented room, spraying 2K with a HVLP gun, painting a panel or two at a time and don't turn the lights on and off when spraying am I right in assuming I have severely reduced any explosion risk?
You should indeed feel sorry. Another member whose response I have had to remove hit the nail on the head - what if someone who doesn't know betters reads it and has a go? Dumb post.nope.
plus , to be fair, i was bored and slightly trolling.
both the above situations i stated where in lab conditions at school, not in my home garage. sorry, couldnt resist.
