Parm
Respect The Sound System
- Towcester
What's the max size drill you can fit in that?
They are students, so so so many possibilities for mischief
Nor can I.
The decal was badly damaged and was impossible to read or duplicate.
220RPM top speed should handle 50mm in steel but once you get a chuck on there's not much daylight under the spindle.What's the max size drill you can fit in that?
Send me one then![]()
Sorry, but I need mine.Besides which, we've seen pics of your workspace - you've not got room.....
Believe it or not, some folk keep multiple lates for their entertainment.![]()
but it was £12 delivered and still works well.
You did well with that, prices for 92s [with or without stand] seem to be all over the place.
Maybe I'll just keep my £10 one...'just because'You bettered me though, I had to collect mine
The base on mine is slightly bent, I assume it's supposed to be flat?
Any chance you can confirm - and perhaps 'The Collective' cab advise how best to flatten it out again if needs be?
A clout from a 14lb sledge, then you can do a post on welding a pipe vice!![]()
Application of a BFH seems effective in many situations, but I suspect this isn't one of them.
Could use the lathe to machine the base flat...
Or even the milling machine, if I could get it set up properly on the bed.![]()
