The_Yellow_Ardvark
https://www.death-clock.org/
- Going Away.
The following was what I wanted the contents of the 2 box's.
This is a gold find.
Mamod Stationary Steam engine.
Needs a lot of work.
Main steam pipe is badly soldered, saddle for axil loose.
But it is complete.
5 small line shaft driven workshop tools, I doubled up on the small grinders.
Just need to locate a line shaft.
Yes, 2 original box's
I thought - what a load of tat - until I saw the last 2 photos - jammy git!![]()
Certainly interested if you have it and it is suitable.Capto? Think I might have an adaptor kicking about if I didn’t give it away already...
That's a shame. Not really sure why they don't do a VDI30 C4 adapter, not that I would be paying Sandvik prices for one even if they didOne I have/had is Vdi40. Same problem you have then. I sacked off the idea and got rid of the capto tooling I had...
Bottom left looks like a hot hardie, for cutting hot steel. Can also be used for marking the centre of a piece of bar by balance before working it. We used to mark the centre of horseshoes like that.the "tuning fork" is for bending.
the top left is a hot chisel.
the ones on the right (top 2, bottom 2) are for making specific shapes- possibly should have a matching top tool.
the two flat blocks are for working inside corners.
the centre tool looks like a tinman's stake for working internal seams etc.
the bottom left triangular tool? not sure
But it is complete.
you jammy git!
You really need a lathe in your life!![]()
1950's Meccano set would provide the line shaft and pulleys, I am sure a man of TYA's calibre could do the rest.
Great drills. I have three union hand crank drills. Just in the middle of refurbishing one of them.In the damp news paper in one box was a surprize.
As I was about to recycle the paper it felt heavy.
A taper shaft and a chuck.
It looked like it would fit the pillar drill I have stalled on, due to a lack of chuck.
Missing a spring, but I will rob one from the grave yard.
In place and working.
That one was a Keen.
View attachment 182640 View attachment 182641
When I got it, it had the wrong chuck fitted.
Fascinating, I had a little lathe made by Keen but the decal was destroyed. What does it say exactly? Can’t quite read it.
