Barking Mat
Cuddler of hedgehogs.
- France, Brittany.
Looking very nice.
I don't like that mains socket! Wish I'd placed it centrally on the side of the cabinet; it will annoy me.
Easily moved. Fit a double so it takes up old and new location covering exiting hole
I'm glad you enjoyed it and thanks for the post; it's nice to get feedback.
When I look back at the thread I think 'bloody hell!' that was a lot of work. A project that size I find rather overwhelming so I simply keep doing little jobs and suddenly it's all finished. As long as you do SOMETHING each day the project will be complete sooner or later but if you do nothing it will never be finished. It doesn't have to be slaving away in the workshop. Sometimes if it is cold and dark outside I sit by the fire with a glass of something and draw some sketches or maybe place an order for components. Time away from the workshop is very valuable for me, stops me doing (so many) stupid things by forcing me to think them through.
Enough of that.
I was undecided about that. There is a lot of inertia in a truck so you don't get the bouncing about that a smaller vehicle does, on the other hand, it would be quite easy to run a ratchet strap around them.
Seconded, batteries contain a godawful amount of energy, no metal attached to you whilst working on them is the only option to avoid shocks
We took the truck out on 'sea trials' south to Dunedin at the weekend. That's six hours each way and quite a marathon but it was a good shakedown. Some overheating on the way down proved to be loose hose clamps and the temporary loss of clutch on the way back was simply the adjuster backing off and in need of a lock-nut.
I fitted some stays so that the back door can be dropped down level and used as a deck. The parts were laser cut and when they came back I found that I had cocked up on the measurements and the slots in the stays nowhere near long enough. After rethinking the design I mounted them upside down and they work very well, probably better than plan A. Strange how things turn out.
View attachment 160005 View attachment 160006 View attachment 160007 View attachment 160008
Add another double one to the left if you have space to give you four sockets . One will always be needed for the phone charger or video game etc. & one for the slow cooker whether it is being used as a cooker/ sterilizer or a gentle back ground heater .I don't like that mains socket! Wish I'd placed it centrally on the side of the cabinet; it will annoy me.
To make things easier on my spine, arms, legs & also to allow my wife & Munchkin to do things . I would have set the batteries on some heavy duty tripple extending 100 kg full ball bearing drawer runners to make a push in / pull out rack . With the battery tray in between them using a 30x30 x 5 mm angle iron frame so that once un locked / untethered you can slide them outboard to pick them up off the tray rather than bending over to drag them out or push them back in .
