pidgeon chit welder
sticking metal since 1962
hi john-g and welcome
never did get to finish sorting it out I think I might have to change one of the wheels so I can put a smaller pulley on it to try and slowdown the roller says it was spinning to fast
I had some heavy rushes to do so made up a spray boom for them last year
the pump work off 12v battery there shouldn't be too much problems with drip if the roller speed is right the pump doesn't run continuously you just switch it on and off to keep the roller wet as needed
my roller he is a bit on the heavy side so I was keeping my eye out for a 6 or 7in pipe something like a flue-pipe or stainless-steel you would probably get away with a plastic type drainage pipe if you were not going to wide
100 mm or the 200 mm pipe brown plastic underground foul water waste pipe filled with high density foam and an axle tube of thin walled exhaust pipe spaced out evenly using plastic stand offs ???? Rivet or self tap the felt to / round the pipe too make the roller having a thin plastic strip cover at/ along the joint
