I can get a meteor cylinder with the 10mm pin in the UK for £24.
Meteor piston, is yours a 10mm pin? Mine is an early saw with no decompression button but it is a 12mm pin. Double check it with the caliper before you commit.
Weekend use but often a full days once I get started. Tree and hedge work. I want to try and repair it to be honest - if nothing else to learn how to do so.
We have 12 acres so hire/electric and even battery are all out in my opinion. There are a lot of neglected hedges and trees.
I bought the cheapest piston on ebay for my 044, cost about £6.50 and it's run well for nearly 2 years now. My plan was to treat it to a barrel and piston if it didn't work out but it saved me the trouble by running perfectly. I picked a saw up today from Gumtree, MS460 to have a look at and tinker with. I had the exhaust off and the piston looks clean, there's a spark but no action so I will take the carb off and see what is going on inside. It needs some new plastics though so I'll see about some from China once it's running.
. Had my 192t pinched when got broken into and replaced it with a 193t 'same but different'. When I get some 'freer' time have to do some tree removing from my neighbours property, plenty of mulch from that exerciseI dont know if this is normal or indicates excessive wear? It was working fine one day and not the next. The marks look a lot worse than they feel - barely perceptible as i run my finger nail over them.
View attachment 175349 View attachment 175350
