A slaters hammer would have a point for piercing slates.
I would imagine that the head is magnetic.
The thing is stubbing in your neck with its nails ...Parts to fix the boiler, was very handy having all of them in the one bag when they are only slightly different like 18/19/22/22.8mm making it rather confusing to work out what went where!
Also got a parrot View attachment 515954
She walks from one arm across your back to the other, I swear she's more dog than chicken as follows you everywhere and cries if you leave her aloneThe thing is stubbing in your neck with its nails ...
I would deserve it a special place at.lunch for next Sunday if in yours
Unconventional pet I like itShe walks from one arm across your back to the other, I swear she's more dog than chicken as follows you everywhere and cries if you leave her alone![]()
The last one I had.....brand new from Machine Mart ...... I made a steel right angle bracket, so.. I could mount it at the right height to the right of the RH tool rest. Using 6mm coach bolts & extended wing nuts . It was not consistently held at 180 degrees when trying to make the second cut and was useless for 4mm or less diameters .Honestly I've got the thing just to understand the indexing part of it, I'm pretty sure I'll faster by hand too
As we don't have a sharpener at work we use a bench grinder for everything
That's why I've got it...The last one I had.....brand new from Machine Mart ...... I made a steel right angle bracket, so.. I could mount it at the right height to the right of the RH tool rest. Using 6mm coach bolts & extended wing nuts . It was not consistently held at 180 degrees when trying to make the second cut and was useless for 4mm or less diameters .
