Pressie to me, justification is that I need to get some 25mm box from the steel suppliers for the kitchen cabinet base build and will have to cut them down to get them on the trailer won't I
The third and hopefully final part of my bad luck.
1st dual mass flywheel on the car disintegrates with little warning. £1600 quid engine needs to be dropped to replace it and the clutch.
2nd Someone wipes out the front of my van because they dont know how to use a roundabout and flee's the scene.
3rd. van starts loosing power intermittently. Sometimes it starts but no throttle and stalls like its not being told to idle.
magic. Could it get any worse. bloomin hope not.
Fingers crossed its the map sensor and not the injectors.
It has and it could but popped down the garage on the way home this morning and had the codes read. Map sensor a short somewhere and injectors. All of which if I'm lucky could be down to the map sensor.Has it got a fly-by-wire throttle 'cable'? If this starts playing up I'd imagine it could produce the resulting aggro you've been experiencing?
Don't think so. Performance is fine right up until revs die completely. Then starts again and runs fine.Could be the fuel pump.
But, I hope it gets better soon.
Normally I'd say you jammy git but I think I'll not bother with the 'jammy' in this case, you're just a git!
Good score there mate, lerrus know what you find within
View attachment 175230 View attachment 175229 30 of these. Does anyone know what they are? they are cast with a really coarse thread in each end.
good job your not local .........i have a spare drum for one of them
I did think about rebar but thought they were too fancy for that but i will try some rebar in them!Rebar joiners?
Time will tell. Empty the van tomorrow and prepare for a 3 day week in the car.
