pressbrake1
- Essex
I’ve got big feet so that gives scale
I’ve got big feet so that gives scaleView attachment 174061 A large steel vice around 500lb in weight 11” jaws. I hounded the first owner of the business for 14yrs the present owner relented after only fiveI’ve got big feet so that gives scale
Think that should be in my placeView attachment 174061 A large steel vice around 500lb in weight 11” jaws. I hounded the first owner of the business for 14yrs the present owner relented after only fiveI’ve got big feet so that gives scale
No I ll use it and your skinny arms aren’t big enough to load it with a job it deservesThink that should be in my place![]()
No I ll use it and your skinny arms aren’t big enough to load it with a job it deserves![]()
I was thinking how well my tea cup would look sitting on it.No I ll use it and your skinny arms aren’t big enough to load it with a job it deserves![]()
And yer fagI was thinking how well my tea cup would look sitting on it.
I will use it. As I do get jobs that require pipe threading. I normally go to my local. So it will a nice machine to use
Yep you are right.
Cast alloy deck with steel bits bolted to it.
Cracking mower, But it has got some compression. Almost need a kick start on it rather than pull cord. My old crf 250 would have less.
Well will give me some more time on the ac tig to repair the deck then. Then paint it up and referb the rest of the parts.
Only thing I will have too look at it repacking the exhaust as is quite loud.
It would be great for holding delicate parts.![]()
They were a cracking mower, the deck normally corroded away but the engine was indestructible!
You might not know but you can usually set the engine rev limit at 4000 rpm on Honda mower engines, Briggs limit is only 3300rpm!
All new mower engines come preset to 2800rpm (to keep the blade speed down & emissions down) but we used to 'tweak' them for our professional customers.![]()
this awesome vice could look great painted an intimidating Alligator green ?
And then her dad says he'll burn the barn down?
Dave H. (the other one)
Our old fella is selling two of those with loads of attachments at the moView attachment 174116 Need one of theseView attachment 174113 View attachment 174114 CPicked up this Wolseley Titan from a mate his morning, plan is to get it sorted and sell it to raise funds foe Saints Wheelchair Rugby here in Northampton. Few bits missing/bent but solid with a working motor.
