Looks like quite an impedance mismatch going on there!!and made up the joint in the loft. in a dry location and completely accessible jelly crimps are totally acceptable.
Network cables rely on a well defined twisted pair structure (by insulation type and thickenss, and twist pitch) to provide a characteristic 100 Ohm impedance, and immunity from crosstalk and interference. Both of those characteristics are compromised in the join that's visible in the images above. A better method of joining would be to terminate both ends of the cable with Ethernet jacks, and using an Ethernet joiner/coupler.how d'ya figure?
Think I would have moved housemany years ago, when I built the garage, I ran Ethernet out to give me Wi-Fi out there. its been working fine til recently.
now it isn't.
I had to extend the wires because I was stupid and cut them too short, the connectors are waterproof but obviously it wasn't a good long term solution.
so i fixed it...
and in doing so gave myself a lot of work refinishing my toilet...
dug up the splice
pulled new wire through the conduit.
then up through the bathroom wall
replaced the plasterboard
and by the front door as i now had a offcut to use
"conduit" replaced (its data, proper conduit is tiny, hard to pull through and expensive by comparison, this works... gimme a break)
Can you link a source or ISO standard for what ‘proper connector’ you mean?the inductance comes from the wire and the capacitance comes from the distance between the wires and the material between, in the wire itself and a proper connector this is designed to all be the same. Where it isn't, like jelly crimps and with random distance between the wires making up each pair, you'll get some of the signal reflected back rather than transmitted.
No single proper connector, but anything with an impedance of between 85-115ohms at 100-250MHz. Have a look up of impedance matching and if want a lot of detail and a very interesting book, a handbook of black magic, high speed digital design, and if you run the numbers, you can see why a small mismatch will be ok but it does degrade the signal at some pointCan you link a source or ISO standard for what ‘proper connector’ you mean?
Nah, wrong thing. If you're in telecoms, maybe return loss is what you're familiar with? This gives a measure of what fraction of the signal is reflected back by discontinuities in the transmission line impedance. Anyway, I'll leave you to it
Do you have access to the hot side air inlet? The hot air being blown out has to come from somewhere, and probably at 30 degC plus, which also has to be cooled, causing a huge reduction to the overall cooling efficiency. On a day like this, a 12,000BTUh unit may only be producing an effective cooling of 4,000BTUh. I'm in the process of channeling the hot side air input via a second hose to the outside.The reverse side...pretty pleased with this. The rough surface was caused by me covering it with an old bag and then adding a ply board and weights as it needed to be kept flat while it cured.
Today it's 30c+ outside and there's very little heat soak coming through the board.
My old machine had x2 ports...new one takes the hot side from the room which is very annoying as it's creating a negative pressure in the room effectively.I'm in the process of channeling the hot side air input via a second hose to the outside.
All finished.many years ago, when I built the garage, I ran Ethernet out to give me Wi-Fi out there. its been working fine til recently.
now it isn't.
so i fixed it...
dug up the splice
