Ideally some form of mid-weight hydraulic oil, but anything liquid will work that won't damage the seals.Which oil do you use in those pumps?
60 years ago the school minibus got a puncture when we were miles from anywhere , the bottle jack wouldn’t work until the driver (science teacher) topped the jack up from his thermos flaskIdeally some form of mid-weight hydraulic oil, but anything liquid will work that won't damage the seals.
More tea Vicar?60 years ago the school minibus got a puncture when we were miles from anywhere , the bottle jack wouldn’t work until the driver (science teacher) topped the jack up from his thermos flask
More tea Vicar
I use this for all my jacks, hydraulic press and engine crane, https://www.westwayoils.co.uk/products/hydraulic-oil-iso-32?variant=31226474561676Which oil do you use in those pumps?
) and when built the curved handrails had to be laminated from shorter pieces as at the time I couldn't source 16 foot lengths of 6" x 2". Over the years the weather hasn't been kind to it and the rail is rotting but I have been able to source two 16 footers to replace them. Original 'curve' - more a series of straight lines wasn't ideal so this time I'm trying to get the replacement 'set' into a proper curve before removing the original (otherwise there'd be nothing to fix it to.
Yes that was a concern initially bending it. In the end I got a Junoesk friend to sit on it while I fixed the clamps - she's a good sport !Twang mind your chin...
Welded clutch was a success!
If you try drilling a hole with that bit you will need the clutch working!
I believe it has effectively 2 clutches, one being the electromagnet on the motor armature and the other one being the friction clutch on the rotary drive assembly so worse case that 2nd clutch will still work and slip it just doesn't have the electromagnetic version which disengages the second it detects a jamIf you try drilling a hole with that bit you will need the clutch working!![]()
oh no.... oh no no no...
it is not knocking... but i don't dare run it any longer.
this is a newly rebuilt rx8 r3 that got recovered in because the oil pressure light was flashing. he also says he heard it start to knock.. good call by the owner. i was 'really' hoping it was the pressure sensor. the rebuilder is being very good about it, no arguments. asked me to diagnose it for him and go from there. i'll call him tomorrow and let him know, and let the owner know the results of the conversation. the likelihood is the pressure regulator is stuck open. that's not a cheap part on its own... i really hope it hasn't done the bearings, but its not good.
hang on a minute. im a idiot. its still a bit lower than expected... but psi is on the outside of the gauge.... ffs. 72psi is still lower than id expect cold but still...oh no.... oh no no no...
