qwakers
- cornwall, united kingdom
thats assuming the pump runs constantly. ill bet it doesnt.Thanks folks. Even with the 10A amd 5 hours run time this is a simple solution.
No. Not at all. Could be a half to a third of an hour normally in total. If the rayburns really hot it will run more.thats assuming the pump runs constantly. ill bet it doesnt.
Mine like books. They'll cope without a screen for a few hours!Until the kids are older and in school and all they want is to sit infront of a screen like vegetables![]()
The store is gravity fed from the Rayburn. It needs to circulate from there round the rads without replumbing all of them!a simplier way way would be gravity fed which uses no pumps but you can just uses bigger feed pipes
Some standard car, but there are two leisure batteries in the shed as well (three if I take the one out of the caravan!)If they are standard car batteries you will need to redo your calculations.
Once they get below 10v they are pretty much done, keep going and you'll wreck the batteries.
To provide a long steady supply you need leisure batteries, designed to be discharged to much lower voltages.
Factored into the Ah ratingIf they are standard car batteries you will need to redo your calculations.
and all it takes is buying extra radiators and plumbing them into the gravity fed system these can be set for open or close when needed by gate valves but these valves will need replacing as they will seize up without usage and wear and tear or by opening and closing them,The store is gravity fed from the Rayburn. It needs to circulate from there round the rads without replumbing all of them!
But Gaz, how is this more simple than buying an inverter, sticking a plug on some wires and using batteries and rads I have?!and all it takes is buying extra radiators and plumbing them into the gravity fed system these can be set for open or close when needed by gate valves but these valves will need replacing as they will seize up without usage and wear and tear or by opening and closing them,
but most dont want to fit them they want simple central heating and both ways are simple
if a power cut does happen you have 3 rads that are still using a gravity fed system and not reliant on the power otherwise its buy a gen and use that for power of the pump and for the heating system a system that can be plugged in via extensions to connect power for pumps/zone valves and heat stat otherwise that system wont run correctly as its power based
the only warning i wall say is dont touch those rads they will be burn hot to the touch as it happens with gravity fed fired from stove heater fired all day long but gives high heat output from them
do not use plastic either the heat in the pipes will also be very red hot
