qwakers
- cornwall, united kingdom
thats assuming the pump runs constantly. ill bet it doesnt.Thanks folks. Even with the 10A amd 5 hours run time this is a simple solution.
No. Not at all. Could be a half to a third of an hour normally in total. If the rayburns really hot it will run more.thats assuming the pump runs constantly. ill bet it doesnt.
Mine like books. They'll cope without a screen for a few hours!Until the kids are older and in school and all they want is to sit infront of a screen like vegetables![]()
The store is gravity fed from the Rayburn. It needs to circulate from there round the rads without replumbing all of them!a simplier way way would be gravity fed which uses no pumps but you can just uses bigger feed pipes
Some standard car, but there are two leisure batteries in the shed as well (three if I take the one out of the caravan!)If they are standard car batteries you will need to redo your calculations.
Once they get below 10v they are pretty much done, keep going and you'll wreck the batteries.
To provide a long steady supply you need leisure batteries, designed to be discharged to much lower voltages.
Factored into the Ah ratingIf they are standard car batteries you will need to redo your calculations.
and all it takes is buying extra radiators and plumbing them into the gravity fed system these can be set for open or close when needed by gate valves but these valves will need replacing as they will seize up without usage and wear and tear or by opening and closing them,The store is gravity fed from the Rayburn. It needs to circulate from there round the rads without replumbing all of them!
But Gaz, how is this more simple than buying an inverter, sticking a plug on some wires and using batteries and rads I have?!and all it takes is buying extra radiators and plumbing them into the gravity fed system these can be set for open or close when needed by gate valves but these valves will need replacing as they will seize up without usage and wear and tear or by opening and closing them,
but most dont want to fit them they want simple central heating and both ways are simple
if a power cut does happen you have 3 rads that are still using a gravity fed system and not reliant on the power otherwise its buy a gen and use that for power of the pump and for the heating system a system that can be plugged in via extensions to connect power for pumps/zone valves and heat stat otherwise that system wont run correctly as its power based
the only warning i wall say is dont touch those rads they will be burn hot to the touch as it happens with gravity fed fired from stove heater fired all day long but gives high heat output from them
do not use plastic either the heat in the pipes will also be very red hot
solar panels and invertor + batterys is the same as a generator both need certain thingsBut Gaz, how is this more simple than buying an inverter, sticking a plug on some wires and using batteries and rads I have?!
I understand the concept as my parents house had it for the old Aga anthracite boiler. It was useless though as the rads were not in places we wanted hot...
Gaz, you might need to read from the start. This was 'how do I circulate heat from my Rayburn all around my house using the existing rads in the event of a powercut, can a car battery do it?'solar panels and invertor + batterys is the same as a generator both need certain things
one depends on solar the other on gas or fuel
a note has to be said that pumps and zone valves need power so if you have both in your system factor that power difference for those on other systems pumps/zone valves and wall stats need to be considered they maybe low power but they do use it factor in zone valves and pumps and your using more power than you think its worth checking your system
vs piping in rads the issue stands at wheres best for core heating of the property though in large houses its in the hallway as you can heat rooms up from the staircase and hallways compared to the old method of chimneys though you could use radiators and tubing to heat rooms up via air heating
freezer fridge would be my preference with lighting and core heating via the stove via gravity system
Yes by default mains is connected to bus bar. If you throw the switch the other way it disconnects the mains inputs and connects the generator inputs.I've a standalone changeover switch buried deep in the garage somewhere. Recently I've been mulling how you would incorporate a changeover switch within an actual cu for a super neat solution:
I presume there are just links in that bottom bus bar?
I ran a secondary mains isolates 240 volt set of four double gang switched three pin sockets into the bungalow and have an external box with 30 or so get of fly lead to get the 3kva pure sine genny hooked up . The heating has one of these alternative sockets adjacent to the changed to switched plate from hard wired socket . If a power cut occurs it's torch out, unplug the heating& replug to stand by socket . Open the outside box take the fly lead to the genny and use auto start then once back inside switch on the heating socket & the auto start heating takes place .Generator, change over switch, have heating, lights, tv, etc
Its a specific type of switch to ensure there is no cross connection, break before make! It would need to be upstream of your main breaker or you wouldnt be able to isolate the house for work.Yes by default mains is connected to bus bar. If you throw the switch the other way it disconnects the mains inputs and connects the generator inputs.
