The weather forecast has got me thinking about power cuts.
My central heating is powered by my solid fuel Rayburn, which heats a thermal store and when the store gets to a set temperature a thermostat triggers two 60W Grundfos circulation pumps.
In a power cut, the pumps obviously won't work and the store will get hot. It could boil but that's not a huge issue as it is a vented system so will 'just' overflow into the header tank.
But @dobbslc and his coffee machine inverter thread got me thinking....
I have loads of 12v car batteries here. 120W isn't that much really. How long would a typical 110Ah lead acid battery run my pumps via an inverter? They aren't on constantly either unless I really have the Rayburn raging so once they've dissipated the heat and cooled that section of the tank they are off again until it reheats.
What size/type of inverter would be needed?
As powercuts arent common bit are a pain when they occur I'd keep it xheap and simple and set it all up as a manual changeover thing so just put a plug and socket on the pump wiring and more the plug to the inverter if there was a power cut.
