NO - they are 12V.I presume everyone is wiring their China diesel heaters into a 3 pin plug? So that it requires to be plugged into an existing socket in your garage to power it up?
That way it is not part of a fixed electrical installation.
NO - they are 12V.
Intended to be used on a car battery supply in boats and caravans etc but most people use a 12V 32amp+ psu - cheap enough on Ebay. They use very little current running but draw a good 20 amps + when the glowplug kicks in.
Ahh I see. Mine is just on a 3 pin plug. PSUs are less than 500w so don't need anything fancy. Only use a few amps when running normally so maybe 30 or 40w.I figure lots of people are using them wired to a psu and I am asking if best to wire that to a lead and plug VS a fixed fused spur.
You are better running them flat out for most of the time. Less soot buildup inside.Was out in the mancupboard from 20 .45 hrs. till 23.14 hrs. tonight temp out side almost minus 2 oC , temp inside after 15 minutes with the heater set to 4 a balmy 15 oC .
I used a fused spur. Of course that may not meet regs as it's not the only fused spur on my circuit. I used a fused box with a red neon as the PSU has quite a high standby current, so I like to switch it fully off when I'm not planning to start it via remote the next morning.I figure lots of people are using them wired to a psu and I am asking if best to wire that to a lead and plug VS a fixed fused spur.
The air isn't an issue, unless the pump is drawing in that much air, the air is making it to the heater.I just ran my heaters again. Looks like having the pumps hidden in a box above the heaters isn't working. The pumps draw air out of the diesel due to the strong action of the piston inside of the metering pump. This air builds up and probably causes inconsistent fuel feed. No biggie, I'll move the pumps so each one is right under its heater.
I bled the hoses but saw that there was still a stream of bubbles coming out of the pump even though the hose into the pump was completely bled. I recently watched John's famous diesel heater videos on YouTube and he said that the air is being extracted from the diesel by the action of the piston. It's too much air... moving the pumps is no big deal and i get something more reliable.The air isn't an issue, unless the pump is drawing in that much air, the air is making it to the heater.
As long as it's just a consistent bubble at a high point in the pipe, I wouldn't worry, just think of it as damper to smooth out the fuel pulses.
That would be a problem.I bled the hoses but saw that there was still a stream of bubbles coming out of the pump even though the hose into the pump was completely bled. I recently watched John's famous diesel heater videos on YouTube and he said that the air is being extracted from the diesel by the action of the piston. It's too much air... moving the pumps is no big deal and i get something more reliable.
I've just finished moving the pumps. I put spring clips on each hose, so they're as air and fluid tight as can be. The spring clips create an even clamp force around the hose, whereas some hose clips pinch the hose and I don't trust those. There is still a steady stream of bubbles being released into the fuel but the air now goes straight up the hose to the heater without building up, so the heater is getting consistent fuel. I did notice that when the pumps were above the heaters, the metering pump frequency would change every so often as though the system was trying to adjust for the inconsistent fuel it was getting due to the air pockets.There will be a leak somewhere, it's just not always practical to cure the leak.
The type of pipe/hose used and the hose clips often don't create a perfect seal. The nipple connections into the pumps are another source, and I'm pretty sure the internals of the pump probably are not the best designed or sealed. They'll be sealed enough to not visibly leak, but the shocking likely allows them to move and let air in.
Ok, I know nothing about this but keen to follow. There's air in diesel, do we agree on this? I just watched a YouTube video of a guy put diesel into a vacuum chamber and show this. I've also seen pro bicycle riders drawing air out of LHM oil before filling brake systems with the "air free" oil. But are you saying that's not whats causing the bubbles I'm seeing because as soon as the air is drawn out by the metering pump it would soak back in ? I don't get why it would do that? Maybe because the pump piston then re-pressurised the diesel-air to push it out the outlet ?If the diesel does see enough of a vacuum to cavitate, any air in the diesel just implodes back in and visbily disappears again.
The ECUs on these are pretty basic, and don't compensate for fuelling issues. They simply spin the fan at X speed, and command the diesel pump at Y frequency.I've just finished moving the pumps. I put spring clips on each hose, so they're as air and fluid tight as can be. The spring clips create an even clamp force around the hose, whereas some hose clips pinch the hose and I don't trust those. There is still a steady stream of bubbles being released into the fuel but the air now goes straight up the hose to the heater without building up, so the heater is getting consistent fuel. I did notice that when the pumps were above the heaters, the metering pump frequency would change every so often as though the system was trying to adjust for the inconsistent fuel it was getting due to the air pockets.
Classic youtuber who doesn't understand why something is happening.The pumps generate bubbles, see attached pic, or this video:
(the video starts at the bit showing the bubbles).
The whole video is largely about air issues.
He's still worth watching as he's understood many parts of the heater even if he has made mistakes. As for the pulsing, maybe only the OEMs know if that's a desirable feature.Classic youtuber who doesn't understand why something is happening.
I got as far as him starting to waffle about the bigger tube absorbing the pulses, and how that's supposedly bad.
The way these heaters work, that makes no difference. The fuel passes into the gauze that surrounds the glow plug, where an air bleed then pushes the fuel through the gauze where it vaporises the fuel creating the flame. The gauze also smooths out those pulses from the pump, otherwise the flame would be very inconsistent.
If anything, a smoother delivery of fuel makes that vaporisation more consistent.
It sounds consistent to me, maybe others can comment ?
79 degreesHave mine running today, does anyone know what temp the green fuel hose is rated for?
