That's exactly what I do, put the correct cable and plug for its maximum rating then use an adapter to suit. Just seems the proper way.Plus are only really designed to handle 1.5mm2 3 core, sticking 2.5mm2 3 core in is GENERALLY possible but can be a pain and can end up with bad terminations and hot spots...
If your going 2.5mm2
then you might as well go
4mm2 H07RN-F 3 core
into 32Amp Blue Plug
connected to a 13amp plug to 32amp socket flylead for future proofing
see below
4mm2 flex
http://www.ebay.co.uk/itm/HO7-H07RN...821461?hash=item2a58b40dd5:g:hEwAAOSwsB9V~pfj
32Amp Blue Plug
http://www.ebay.co.uk/itm/32-amp-3-...907685?hash=item33af089665:g:oFwAAOSwq7JUGAUp
13Amp to 32Amp flylead
http://www.ebay.co.uk/itm/13-Amp-Pl...hash=item1ea8aecaf6:m:mzRKCmczige2ahaNEdWc-gA
But until you get a 32Amp socket and suitable supply then your restricted to what the machine can do on 13Amps..
Your link is to 1.5! Or were youu just using the link for the type of cable not csa.I now have2 meters of this in 2.5mm-http://www.ebay.co.uk/itm/HO7-H07RN-F-H07-3-Core-Rubber-Sheathed-Mains-Cable-1-5mm-Sold-By-The-Metre-/181876830702?hash=item2a58b431ee:g:1uYAAOSwVL1V~pwR and a rubber plug best one they had
id give u a bloody medal -if u could get 10.0mm in a 13 amp plug .2.5mm max and that's pushing itI would not be happy with 10mm cable in a 13A plug
For medal purposes, how much 10mm cable has to fit in the plug, can I cut parts and does it have to work?
Thats them Benhttp://www.ebay.co.uk/itm/Uninsulat...660321?hash=item2a5077e1e1:g:6DwAAOSwgkRVTIIP These the ones i'm looking for?? i think i have a crimping tool somewhere should they be soldered as well or is just crimping sound enough. Sorry for all the questions this is turning into a step by step guide just want to make sure i do everything right
