you will be cursing them as they are the most annoying things to get off when they go rusty and your there with a small hacksaw cutting them in the most uncomfortable position going
Noooo.Take the lot out and fit a modern alternative
Fluidmaster Push Button Cable Dual-Flush Valve - Screwfix
Order online at Screwfix.com. Fluidmaster valve with top, front or side dual-flush operation. Fully height adjustable overflow, no cutting required. Twist and release action for easy maintenance. Cable length 350mm. FREE next day delivery available, free collection in 1 minute.www.screwfix.com
Is it any different to being drunk and "Talking to God on the big white telephone" ??The few times I've had to endure this misery I've used a oscillating tool with a carbide tipped blade.
Cuts through them in a jiffy but you're still face to face with a toilet.![]()
Its fine when its your own toilet, when its someone elses its just a bit yuk!Is it any different to being drunk and "Talking to God on the big white telephone" ??
At least you've had the dubious benefits of a few beers before you drive the porcelain bus.Is it any different to being drunk and "Talking to God on the big white telephone" ??
Question for the water-welders...
Do I need to replace the entire green-and-transparent thingy (and, if so, what's the proper name?) or is there an easier fix?
Then again it's them that's got to clean up..Its fine when its your own toilet, when its someone elses its just a bit yuk!
Claim it must've been the cat...Seeing as we are talking about toilets ……. The other night I got up at about 3am for a leak, 3/4 asleep as usual. Wondered why I was getting wet & realised I’d left the lid downOn hands & knees cleaning it up, just what I need at that time of night. Shan’t do that again.
That is a cleaver cat that can put the seat down after it has used the toilet.Claim it must've been the cat...
In fact the Romans used pi$$ as a cleaner even a tooth whitener...
I actually knew someone who trained their cat to kind of stand on the seat and use the people toilet, not sure if it was 100% reliable tho..That is a cleaver cat that can put the seat down after it has used the toilet.
How many men are 100% reliable ? Or for that matter women.I actually knew someone who trained their cat to kind of stand on the seat and use the people toilet, not sure if it was 100% reliable tho..
I remember doing mine at the old house, it went from a few hours work to two whole days, and needed the wall repairing where the tank holding screws were only holding in the tiles they were screwed to, which had come loose, there was a huge gap behind them.you wont be saying wow where when your bent over the toilet cutting the 2 bolts off of them
wont he kayos
Viva 1 1/2" Close Coupling Kit - Screwfix
Order online at Screwfix.com. Close coupling kit, for connecting toilet cistern to bowl. FREE next day delivery available, free collection in 1 minute.www.screwfix.com
I replaced mine as a whole kit. As has been said, to replace that silly bit of ‘cellophane’, meant removing the whole cistern anyway.if you take off get the whole kit for the toilet pan and refit new
new bolts new seal and new pan bar is my advice you end up cutting the old ones off anyway
