Brad93
- Essex, United Kingdom
I would say that’s gone mate, it’s not listed on the used machines section of their site. Worth an email thought
Well I put mine in the boot of the car and I didn’t even have to put the seats down![]()
Mondeo hatch back.Volvo estate?![]()
Aye but that wee tiddler could have been carried in a seat satchel on a push bikeWell I put mine in the boot of the car and I didn’t even have to put the seats down![]()
You can lift them easily onto a pallet with two engine cranes, as the have the holes through the base, for a tube.
On to pallet then winch it on to your plant trailer, or similar.
I hired a tail lift van once wasnt too much from memory.
If you want the machine there are always ways.
Doddle with a tele handler.
Yep definitely aware of this. We had for a short time, a Harrison 140, many years ago before I was into metalworking, but it didn’t turn anything straight.Dont be tempted to take the lathe off the cabinet
They are set up at the factory
The headstock should have some movement relative to the bed. On mine there's 4 cap head bolts holding it in place and it does need adjusting, it cuts a taper of about four thou' per foot!
This thing cut about 1/2" OUT per foot lol
I think it may have been lifted by the chuck/spindle tbhIndicating someone's been messing with it already (?)![]()
No idea mate it was sold years and years agoOn these harrisons the headstock is scraped to and sits on vees. Try as you might there is no adjustments there.
Unless it's different because it's a gap bed?
I thought mine was needing adjusted but even if you loosen the bolts and tap it around it always goes back to where it started when you tighten the bolts.
If you are having issues your bed may have a twist or your bearings may need tightening in the headstock. That cured my problems.
